11-02-2014, 10:31 PM | #1 |
1936 ford trans upgrade
I have a 36 coupe I need to redo the trans I heard that you can put a newer set of gears in the trans does any body know what years can be put in the trans thanks the car is all stock mike
11-02-2014, 11:04 PM | #2 |
Re: 1936 ford trans upgrade
You are probably talking about the later gears with improved syncronizers. If so, the '39-'48 gears are what you want. I would suggest picking up a copy of Mac Van Pelts transmission book. Will tell you everything you need to know about these early Ford transmission.
Here are some pictures of a transmission I built this past May for a friends '36 fordor touring sedan. Used his '36 case with serial # that matches frame & title, '40 - '48 pass car side loader gears that were in excellent condition, '39 top/tower, '36 shift lever, and '35-'36 rear mount/bearing retainer. Working like a charm in his '36. I got to drive this '36 at the Gettysburg ENM in June, and felt that it shifts much better than my '35 Avatar fordor that still has its stock transmission. Also, I could not make this '36 jump out of second gear no matter what I did, like my '35 jumps out of second now. Will be making this same gear change on two of my '35's as soon as possible.
John "Never give up on what you really want to do. The person with big dreams is more powerful than one with all the facts". Albert Einstein Last edited by JM 35 Sedan; 11-03-2014 at 03:22 PM. |
11-03-2014, 09:44 AM | #3 |
Nomad |
