10-30-2021, 07:00 AM | #1 |
6 volt turn signals
I am installing turn signals on my car. I am using the cowl lights for the front. Does anyone a source for a 6 volt assembly for the rear?
10-30-2021, 10:23 AM | #2 |
Re: 6 volt turn signals
On my '41 p-u I am using the original 6 volt brake lights but with double filament incandescent bulbs for 64 CP total each bulb. My turn signal switch has 8 wires.
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria Last edited by Anteek29; 10-31-2021 at 11:42 AM. |
10-30-2021, 10:27 AM | #3 |
I use an LED bar in the rear window.
That is where people look for your brake lights |
10-30-2021, 10:28 AM | #4 |
I mounted a RH tail light the same as the LH one and used the brake light portion of both.
If you don't hear a rumor by 10 AM, start one!. Got my education out behind the barn! Last edited by katy; 10-30-2021 at 11:01 AM. |
10-30-2021, 11:04 AM | #5 |
Never heard that one before, I guess I'm just old school.
10-30-2021, 11:56 AM | #6 |
I'm running these turn signals in the bumpers: https://www.snydersantiqueauto.com/p...4157&cat=41729 They look decent and work well. |
10-30-2021, 12:04 PM | #7 |
I use 6 volt double filament incandescent cowl lights and led s for the tail lights. I know the led s are not original looking but in today's traffic i want them to know when I'm slowing down, turning or stopping. They are a lot more visible and people seem to react a lot faster after I installed them.
10-30-2021, 02:33 PM | #8 |
The cowls or parks are fine for the front.
What is wrong with using what you have for the rear ? [ assuming you're using two lights in the rear]. If you want to convert to LED in the rear then all the vendors seem to have them. |
10-30-2021, 05:44 PM | #9 |
Like Katy said on my 41 the signal kit runs the rear wires off the brake light switch and you use the brake lights for the rear turn lights
