Old 08-08-2019, 01:46 PM   #1
Tom-MI
Tom-MI's Avatar
Default Turn signal flasher
This may seem elementary but I need some help. I am making up some turn signals. All seemed to be going good until I got to the flasher. It is a three prong flasher. There is a "P" at the 12 o'clock position. A "L" at the 3 o'clock position and a "X" at the 9 o'clock position, What wire is suppose to go to each letter. There are no clues on the can.. I tried a picture but the markings are too faint to read.
Thanks
Tom-MI is offline   Reply With Quote
Old 08-08-2019, 01:55 PM   #2
Jersey Devil
Jersey Devil's Avatar
Default Re: Turn signal flasher
Tom
X is where voltage is applied
L. Goes to turn signal switch
P is for pilot light on turn signal switch if provided.
If you google 3 post flasher there are a few diagrams.
Hope this helps,
Tom
Jersey Devil is offline   Reply With Quote
Old 08-08-2019, 01:56 PM   #3
sdpine29
If I remember X goes to fused power L goes to load (the switch) and P is pilot light on the switch or on the dash. Try that.....sam
sdpine29 is offline   Reply With Quote
Old 08-08-2019, 03:45 PM   #4
JSeery
JSeery's Avatar
Here are a couple of diagrams. I notice one diagram has the flasher as the power source for the indicator and the other one has the flasher as the ground for the indicator.
Old 08-08-2019, 04:22 PM   #5
slowforty
slowforty's Avatar
Also make sure the turn signal bulbs are large enough to make the flasher operate.
slowforty is offline   Reply With Quote
Old 08-08-2019, 11:48 PM   #6
Tom-MI
Tom-MI's Avatar
Thanks Guys! Everything is working as it should!
Old 08-09-2019, 01:35 AM   #7
RalphM
RalphM's Avatar
Maybe I need to switch to a three prong flasher and put a light in. I’ve been tooling around in my AV8 and thinking my signals were working, but tonight another car and I were both making lefts on a green light opposite each other. He seemed hesitant so when I stopped, I checked my signals and sure enough, it quit working.
RalphM is offline   Reply With Quote
Old 08-18-2019, 07:31 PM   #8
Lawson Cox
Lawson Cox's Avatar
On the subject of turn signals. Anyone know of a loud "clicker" to use to indicate signals are working. The little "beeper" is annoying as Chebbys"
Old 08-18-2019, 07:47 PM   #9
edhd58
edhd58's Avatar
i use a "heavy duty" one, with 1157 up front and led at rear, it clicks fairly loud
edhd58 is offline   Reply With Quote
Old 08-19-2019, 03:46 AM   #10
Graeme / New Zealand
Graeme / New Zealand's Avatar
Lawson I use a Tridon / Novita LL535 6v 3 pin flasher from Rock Auto ( USA made, don't get fooled by chinese made L535) plenty loud to hear. Got mine mounted behind the radio grill in dash... don't need no annoying "beepers".
GB
"you can't make honey out of dog sh*t"
"You're a long time looking at the lid"
Graeme / New Zealand is offline   Reply With Quote
