02-28-2018, 04:05 PM | #1 |
Galaxie 289 second oil pressure port?
Does the 289 engine have an 2nd oil port to install a direct pressure oil gauge. Or, do I have to install a brass fitting to "T" off? Thanks Rob
02-28-2018, 07:18 PM | #2 |
Re: Galaxie 289 second oil pressure port?
There's one right behind the intake manifold at the back of the engine that I always use for direct oil pressure (most of the Ford motors from the 60s have the same spot) and there's one up front that the factory used with a hex nipple and electric oil pressure sender. The one on the front is on the driver's side, just up from the oil filter.
If you have troubles finding it, I can probably take some pics of one I have out on a stand... Mike |
03-01-2018, 08:12 AM | #3 |
I would say you need a "T". On my 66 - 289, The only plug at the back is to drain the water out of the block and that is down low on the side.
03-01-2018, 10:45 AM | #4 |
Ok guys, I checked the back of the engine and cannot find a plug to port the oil gauge. I scanned the area with an inspection camera I use to check between walls.
03-01-2018, 10:58 AM | #5 |
I have never seen an oil galley plug behind the intake either. (Unless you're looking at an orange engine with the distributor at the wrong end!)
03-01-2018, 11:04 AM | #6 |
Wonder if it got confused with the 351C/M-400?
DIAGNOSED CDO - (OCD In Correct Alphabetical Order) |
03-08-2018, 11:16 AM | #7 |
If you're wanting to have both a gauge and a dash lite get a dual sender.
Milt/Las Vegas |
03-08-2018, 02:01 PM | #8 |
Shoulda gotta Y-block
