05-16-2022, 12:46 PM | #1 |
Early vs. late
Ordered points without pulling Distributor first, guess mine was an early year after all. Is this a Norse brand rotor?
05-16-2022, 12:55 PM | #2 |
Re: Early vs. late
05-16-2022, 02:05 PM | #3 |
Re: Early vs. late
mid '36 to '41
Charlie ny |
05-16-2022, 03:54 PM | #4 |
Re: Early vs. late
05-16-2022, 04:12 PM | #5 |
Re: Early vs. late
You will need to take that dist off to do anything with it. Then even with new points, it works best when set up on a dist. machine. There is a shop, I believe on TN ave in Lonsdale, Knoxville that has a machine. You will need to ask around that area.
05-16-2022, 05:58 PM | #6 |
Re: Early vs. late
05-17-2022, 04:44 AM | #7 |
Re: Early vs. late
Those points are 32-36. The rotor is 37-41 or, as Charlie says, late 36-41
05-17-2022, 06:44 AM | #8 |
Re: Early vs. late
Tudie,
Box it up and send it 3RD Gen in McMinnville Tenn...Michael Driskell.... hisself will square you away. It's easy to see how this happened....early '36 used those points and midyear '36 used that rotor. Michael has the machine/s to spin it up. Charlie ny |
05-17-2022, 12:25 PM | #9 |
Re: Early vs. late
Thanks, I actually have the correct points and what looks like the correct rotor on order from Third Gen. They are not too far away. If I knew they did this I probably would have had it back by now, Huh? Oh well, learning as I go has been fun and I’m ready for another one. Anyone trade a couple of Harleys for a 39?
05-17-2022, 04:17 PM | #10 |
Re: Early vs. late
Michael may need an apprentice .
Charlie ny |
05-17-2022, 04:49 PM | #11 |
Re: Early vs. late
He is shorthanded at the present time.
05-17-2022, 06:56 PM | #12 |
Re: Early vs. late
05-18-2022, 12:40 PM | #13 |
Re: Early vs. late
Just off the phone with Mike @ 3rd. Gen. I do have a mixture of years. He walked me through, had me send pictures to confirm everything, I decided to buy one of his and keep mine for a spare. Great help and company from my experience and thanks again for the recommendation. I may have a leg in the door as an apprentice now.
05-23-2022, 08:12 PM | #14 |
Re: Early vs. late
Well, installed new rebuilt distributor. Started easy and sounded better. Didn’t stumble at top of shifts. Thought everything was great. Took her a little farther down the road a second time and would start loosing power under load. I think I’m good on the electrical side except to change out ignition wire. I believe it’s a venting problem or clogging filter at electric pump. Still doesn’t want to take gas. I blew compressed air into vent tube at filler neck but it’s pouring rain here in East Tennessee. Will take her out when it dries up and see if that did it. If not,I’m going to have to find somebody around Maryville Tn. To have a look see. Thanks again for all advice and commentary.
05-24-2022, 08:14 AM | #15 |
Re: Early vs. late
If all else fails bring it here to McMinnville in a couple weeks.
I appologize as I dont remember, but did you change your condenser. If you are running the adapter plate I use a FD72 Condenser. Have you checked your primary and secondary resistance of your coil? What part# coil are you using |
05-24-2022, 11:05 AM | #16 | |
Re: Early vs. late
05-26-2022, 02:46 PM | #17 |
Re: Early vs. late
Hello, you’re not too far from me, I got it done by Third Gen. Good, and fast work. Thanks
