Old 12-29-2023, 02:31 PM   #21
johnbuckley
johnbuckley's Avatar
Default Re: will not idle
You can hot wire it to aid diagnosis and thus eliminate the pop out and ammeter as possible culprits. Diagram here
Old 12-29-2023, 10:52 PM   #22
bigmegina
bigmegina's Avatar
Originally Posted by k gilmore View Post
Replaced the carburetor, new manifolds, gaskets, checked timing, and replaced the distributor with a "rebuilt" pop-out. The car will not idle; any suggestions?
mine would not either after sitting for 10 years.checked fuel system rebuilt carb no luck.pop out ignition was the problem.replaced it with a new one and fired right up and idels great.
bigmegina is offline   Reply With Quote
