09-22-2016, 07:05 PM | #1 |
how to adj toe in need help
hello
my toe is about 1" off and I need to adj to correct setting I do not need the setting just need to know how to adj it what do I loosen and what do I turn to make adj do you adj one side or both thank you kevin 1930 tudor |
09-22-2016, 07:23 PM | #2 |
Re: how to adj toe in need help
Check out the link to Marco's site, he has some good information.
http://www.abarnyard.com/workshop/align.htm Bob |
09-22-2016, 08:31 PM | #3 |
When you loosen the end clamps on the tie rod, then you can turn the rod and it adjusts both ends.
09-22-2016, 08:49 PM | #4 |
thank you tom and bob I bought a wheel-o-matic toe mach with shipping for 57.00 I got the one for small cars wish I got the bigger one but made it work got it adj in spec now I hope I don't ware out anymore tires I have to go to smith and jones to get new bolts to put in the tie rod ends to tighten them then test drive it it was almost a inch to far toe in
kevin 1930 tudor |
09-22-2016, 10:10 PM | #5 |
must have wandered all over the road
'31 180A |
09-22-2016, 11:48 PM | #6 |
09-23-2016, 01:22 AM | #7 |
Kevin, call me again if you need me to walk you thru that process again. Glad to know it wasn't something more severe, huh?
09-23-2016, 06:17 AM | #8 |
How did you keep tires on it ? You obviously did not drive much. Wayne
09-23-2016, 06:19 AM | #9 |
09-23-2016, 08:01 AM | #10 |
When I bought my A the toe in was also about an inch or more. Terrible to drive. Drove it home, 170 miles and completely wore out an almost new set of fire stones on the front. I adjusted my toe in with a tape measure after checking rim trueness. My new tires haven't wore hardly a bit in many thousands of miles and drives great.
