07-08-2016, 09:22 PM | #1 |
pulling rear end tomorrow
hello
I will be pulling the rear end tomorrow to fix the clutch fork can you leave the starter on the eng to pull the transmission out or is it best to remove it thank you kevin 1930 tudor 1923 roadster p/u |
07-08-2016, 09:26 PM | #2 |
Re: pulling rear end tomorrow
Starter can stay on the flywheel housing. You'll part the joint between the flywheel housing and the bell housing.
Still, it may give you "wiggle room" to remove the starter. With your body in place you may be thankful for that. Joe K
Shudda kept the horse. |
07-08-2016, 10:02 PM | #3 |
It's been a few years, but the last clutch I installed I think I removed the U joint for clearance. I left the starter in place.
07-08-2016, 11:01 PM | #4 |
When I replaced my clutch throw out bearing, I left the starter in place.
07-09-2016, 07:24 AM | #5 |
I don't know what "Pulling the rear" means to you, I didn't pull the rear to change the trans in my coupe. Just remove the bolts on the spring and roll it back and inch or two and push the torque tube out of the way. Removing the bell housing (and leaving the starter in place) from the flywheel housing gives plenty of access.
Terry |
07-09-2016, 10:44 AM | #6 | |
Thank You;
Brian French; 1930 Briggs Town Sedan |
07-09-2016, 11:23 AM | #7 |
Yes! I'm sorry! In rereading it I see I didn't make that clear! DON"T TRY TO TAKE THE SPRING PERCH BOLT OUT! Model A springs can literally kill you. Very Dangerous! Don't ever disconnect the spring perch bolts with out a spreader. I had one almost hit me in the leg. It was a homemade spreader and the force of the spring bent the 3/4 adjusting screw instantaneously. When it bent it slipped out of position and flew across the work area. Pics in my profile under "My A" Yes. I was referring to the two U- bolts at the peak of the spring.
07-09-2016, 05:56 PM | #8 | |
I was not aware that you could sneak that apart at the U joint, without dropping the rear axle; brake rods, e brake rods and shocks. This is a real time and effort saver. Thank you so very much for that piece of information. Thank You;
07-09-2016, 07:07 PM | #9 |
hello terry
did you have to take the brake lines off or just drop and move the torque tube? I was lucky I was able to fix from under the bell housing I took a pair of needle nose pliers put the pin in the clutch fork and use a punch to put it back in I found the pin broke in two in the bottom of the bell housing kevin 1930 tudor |
07-09-2016, 07:44 PM | #10 |
Brian and Kevin, A few days ago I was complaining about my memory loss /mental overcrowding. This is an example of it. Sorry if there's any confusion. The shocks and brakes were not an issue because I have hyd. brakes and tube shocks. Both had enough flex in them that I recall just taking the spring clamp off and pushing it out of the way so I could remove the transmission and clutch. Now that I recall , I did have to release the E-brake cables, but again, this his someone else's design, not Ford. I try keeping the car all stock, but I don't bother to change what someone else has done. I'm no fan of Hyd Brakes since I got my other coupe which has the stock Mechanicals on it, and they're going to stay on it! Shocks? well, maybe due to the high cost of originals. Again, My apologies for any confusion!
Terry |
07-09-2016, 09:47 PM | #11 |
you might wanna edit post #5; as it stands it is misleading for someone who has a stock setup; and not all future readers will read thru the entire thread to realize your comments were not meant for stock equipment
'31 180A |
