03-27-2015, 12:49 PM | #1 |
T-5 Return Spring
When using the Cornhusker bellhousing what do you use for a return spring? The aluminum bell housing has no place to use the original style spring?
03-27-2015, 01:04 PM | #2 |
Re: T-5 Return Spring
As I explain in the instructions a small tab needs to be fabricated that bolts to the top bearing retainer bolt. The furnished spring hooks to this tab and to the hub to keep it in constant tension against the fork.
03-27-2015, 01:09 PM | #3 |
Thread Tools | |
Display Modes | |
