Old 02-19-2016, 01:35 AM   #1
roh1332
roh1332's Avatar
Default Where next
I have recently acquired a 1928 model A closed cab pick up. It was running about 4 years ago. I can get it to turn over now with a new battery, but won't turn over. Any thoughts on where to go next, carburetor or distributor? just trouble shooting. Will eventually get both fixed up. Thanks.
roh1332 is offline   Reply With Quote
Old 02-19-2016, 01:40 AM   #2
Lycoming-8
Default Re: Where next
In the last part of the second sentence above, I asume you mean it won't Fire. Is that correct? If so, the fuel, and ignition systems are both suspect at this point.
Lycoming-8 is offline   Reply With Quote
Old 02-19-2016, 01:53 AM   #3
Tom Wesenberg
Tom Wesenberg's Avatar
Points often need to be cleaned after setting unused for a period of time. Don't jump in and start changing parts, do some diagnostic checks first. Hold the coil wire 1/4" from a head nut and see if you get a hot blue spark.
Next pull the choke while you crank a couple revolutions to see if gas will run out the carb intake.
My guess is you just need to clean the points contacts. If you don't get a good spark, then stop the engine with the points open, then short the contacts with a screwdriver to see if you now get a hot spark. This will verify that the contacts need to be cleaned.
Old 02-19-2016, 10:36 AM   #4
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
If it has spark, a couple of POOFS with starting fluid will tell you if its' NOT getting fuel.
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 02-19-2016, 10:52 AM   #5
1Tudoor
1Tudoor's Avatar
All of the above & not a bad idea to remove the plugs & see what they look like ---clean them w/ a brass brush & re gap if needed. At the same time put a small amount of oil in the cylinders to help compression & lubrication .
BTW, that's a nice looking PU !
1Tudoor is offline   Reply With Quote
Old 02-19-2016, 11:46 AM   #6
captndan
captndan's Avatar
After sitting four years bad fuel is the first suspect. Drain all fuel including the carb and start fresh. Then go to the distributer like the others have said.
captndan is offline   Reply With Quote
Old 02-19-2016, 11:52 AM   #7
captndan
captndan's Avatar
Another thought. I had one like that and started fresh. Ran fine but after a couple miles it died. Seems the fresh fuel loosened the crud in the tank and it plugged a 'new' fuel filter.
Old 02-19-2016, 01:07 PM   #8
Sunnybrook Farm
Sunnybrook Farm's Avatar
Mine would barely turn over, just wouldn't go fast enough to do anything. I eventually found that the water pump had practically locked up and was like a brake. It probably would have cranked over normally had I took the belt off.
Sunnybrook Farm is offline   Reply With Quote
Old 02-19-2016, 06:10 PM   #9
1955cj5
1955cj5's Avatar
One more thing to keep in mind...
When we pulled my pickup out of the barn last spring after some years sitting it would not fire...but it cranked over fine
There was no power at the points, and this was traced to faulty ignition switch...
It is not a pop-out switch, just an aftermarket switch. Checked it with a meter and found it would work at about half way between on and off......the old A fired right up..!
Early '29 CCPU that had a 4-speed, but not any more.......in the family since '62
1955cj5 is offline   Reply With Quote
Old 02-19-2016, 06:37 PM   #10
C26Pinelake
Drain the gasoline and use it to burn stumps. After four years it is garbage. Wayne
C26Pinelake is offline   Reply With Quote
Old 02-20-2016, 12:38 AM   #11
roh1332
roh1332's Avatar
Thanks for the advice. Gives me some starting points.
