08-05-2021, 11:11 AM | #1 |
59-A fuel pump push rod bushing
Tearing down a 59-A for rebuild when I removed the fuel pump push rod
bushing the last person working on it removed about 1/2 inch from the bottom. More oil to the rear cam bearing-? I know it has been apart before cylinders are .030 over. Any ideas should I shorten the new one-? Thanks for any input. Mike |
08-05-2021, 11:56 AM | #2 |
Re: 59-A fuel pump push rod bushing
Is the oil passage uncovered?
08-05-2021, 02:02 PM | #3 |
08-05-2021, 02:25 PM | #4 | |
It's possible someone installed a non Ford bushing in the past. |
