07-16-2018, 09:43 AM | #1 |
1946 -1948 ford mercury rear suspension
Does anyone know what the correct measurement between the two spring perch holes should be on these rear axles? My car is a 48 Mercury. In other words, the distance between the two mounting holes for the rear spring shackles. My car measures 47 1/2 inches, center to center. The arm on the passenger side looks as if it might be bent a little. Does anyone have a rear axle where they could check this measurement?
Thanks! Bill in Conn. |
07-16-2018, 10:08 AM | #2 |
Re: 1946 -1948 ford mercury rear suspension
It's hard to accurately get a true measurement but the measurement I get on my '46 looks like 48 and 3/8"/ 48 and 1/2", an inch difference is a lot. You should be able to eyeball it from side to side to see the bent part. Can you take a centerline from the housing to each shackle mount to verify the bent dimension?
07-16-2018, 10:40 AM | #3 |
I have a '46-'48 differential under the rear of my '36, it is a Columbia, however I don't think that makes that much difference.
You mentioned that a "bar on the right side appears to be bent". The bar you are talking about is the sway bar that the '47-48's had. The slight off-set is very correct.. I have attached a pix of the differential under my car which clearly shows the slight bend in the sway bar. I believe the purpose is to clear the tail pipe.
Bill.... 36 5 win cpe |
07-16-2018, 10:46 AM | #4 |
Pat, are you saying that the spring shackle mount on the rear ps is bent.
07-16-2018, 11:27 AM | #5 |
My track bar is O.K. My concern is the perch that is part of the rear end housing that hols the rear spring. Thanks for the good input!
Bill |
07-16-2018, 12:26 PM | #6 |
Mart. |
07-17-2018, 05:48 AM | #7 |
Thanks everyone for your help. Heated up arm and straightened right rear spring perch. We're in good shape now!
Bill |
07-17-2018, 07:54 AM | #8 |
Dimensions from the old Street Rodder article.....hangars are 46-3/4" wide from '41-'48. DD
07-17-2018, 08:28 AM | #9 |
I can plainly see what the article states but I rechecked the spare '46 rear I have and it measures 48 and 1/2". Strange, it came out of a stock low milage car.
07-17-2018, 01:46 PM | #10 |
That figure in the article looks to be about an inch off from reality. It shows the 1941 as being the same and I know for sure they are not. The 1941 was still a narrow rear axle and the later 42 thru 48 were not.
07-17-2018, 09:41 PM | #11 |
According to the article my 42 has a 41 rear end, grease fitting and all.
07-18-2018, 07:01 PM | #12 |
Thanks again. Really good input. Ford Barn folks are the best!
Bill in Conn. |
07-24-2018, 05:32 AM | #13 |
