12-02-2021, 07:01 AM | #21 |
Re: My next adventure
I think I fixed the before picture.
Cheers, Jim&Sandy McGregor, IA |
12-02-2021, 07:01 AM | #22 |
Thanks
12-02-2021, 01:58 PM | #23 |
NOT ....but the "After" sure is pretty! DD |
12-02-2021, 04:52 PM | #24 |
"Before" worked for me this morning. Perhaps it is because he just posted a new link and left the old one which didn't work (and still doesn't).
12-02-2021, 05:04 PM | #25 |
Thanks.
12-02-2021, 05:26 PM | #26 |
12-02-2021, 08:05 PM | #27 |
I got a kit from Early Ford parts in San Dimas. Thanks,
12-02-2021, 10:04 PM | #28 |
In my book you qualify for the 'Legends in JB Weld' award! Holy cow. Earl Scruggs would be proud to wield a banjo like that! Hmmmm I before E except after C. Hmmmmm
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-02-2021, 10:10 PM | #29 |
...."or preceding a "G", as in "neighbor" and weigh".
12-03-2021, 08:07 AM | #30 |
Thanks, the JB “wield” was pretty good to work with. In the bigger gaps it took two applications and even some masking tape to keep it from sagging.
12-03-2021, 05:43 PM | #31 |
Moving on, I have the steering box kit from early ford parts and I have the sector roller fitted to the shaft. How should I fix the roller pin (that goes through the needle bearings) so it does not come out of the holder? The old one was mushroomed on both ends, I had to grind an end off. The new pin is chamfered.
12-13-2021, 10:29 AM | #32 |
https://www.fordbarn.com/forum/pictu...ictureid=44344
Steering wheel and rebuilt box installed. What next? I know it’s a question only I can answer. There is still that “vacuum” after one project is done. Guess I’ll fill it with two wheels during our record breaking warm spell.
12-13-2021, 11:23 AM | #33 |
That looks great!
12-13-2021, 11:43 AM | #34 |
Very nice work on that steering wheel! Sounds like you're going through all the systems - one at a time . . . way to go!
12-13-2021, 12:02 PM | #35 |
86 you have done a masterful job on the wheel, and I can only say that you will do the same on the s box.
Merry Christmas. jim |
