01-15-2018, 11:34 AM | #1 |
ford 39-48 emergency cable conduits
I used to buy these conduits from a small business vendor but can't find him anymore. Does anyone make/sell these conduits anymore?
01-15-2018, 12:15 PM | #2 |
Re: ford 39-48 emergency cable conduits
This came up a while back, try the search function. Some one had a good solution for this.
Karl |
01-15-2018, 12:25 PM | #3 |
01-15-2018, 12:26 PM | #4 | |
Check with Richard or Dennis Lacy, Early V8 Garage in Covina, Ca. A large part of their business is providing hydraulic brake conversion components for early Fords.
01-16-2018, 09:22 AM | #5 |
John, First let me apologize for not thanking you for the suggestion. It was appreciated. I looked at their web site and it did not have any suggestion as to backing plates or repair. But they did have a spot for questions, so I sent them a message and they did not respond. As you were the only one who responded on the V8 web site, I turned to the Fordbarn.
01-16-2018, 09:26 AM | #6 | |
I tried Google searching for 1/2 inch tubing and got nowhere (except for some malware). Thanks for this site. |
01-16-2018, 09:40 AM | #7 | |
Someone posted on an older thread that they bought these tubes from C&G, but I'm not sure they still carry these. Some years ago, I made a couple sets of these conduits using some 1/2" steel tubing and brazed them in place on the rear backing plates. This was not that difficult to do and worked very well. I found several old threads here explaining details on how this was done. A quick search should bring these up.
01-16-2018, 11:15 AM | #8 |
Here is how I handled it
https://www.fordbarn.com/forum/showp...3&postcount=24 |
01-16-2018, 12:45 PM | #9 | |
01-16-2018, 02:46 PM | #10 |
Just Googled and found two sources pretty quickly. Here's one possibility. Buy on line at $0.25/inch:
http://www.speedymetals.com/pc-3411-...teel-tube.aspx
01-16-2018, 04:18 PM | #11 |
For what it's worth, in case the idea may be of use to anybody, I was able to simulate the rubber boots (to a certain extent at least) with some heat shrink tube. It was big enough (just) to slightly stretch over the end of the tube, but when fully shrunk did not grip tight on the cable. I reused an old cable, the boots were gone. I had a new cable bought a few years ago and the boots had split already. The quality of the rubber is nowhere near good enough.
Mart. |
Thread Tools | |
Display Modes | |
