Old 08-31-2017, 10:51 AM   #1
Highboy34
Default 49-53 Truck Engine Pan Support
On these engines, there is a bracket on the bottom of the tranny clutch cover extending forward under the back of the engine pan that I assume is some kind of pan support. Mine is missing its rubber pad that I believe the rear of the pan sits on. Is that it's function, or is it some kind of rear engine support? Appreciate any and all advice on its function and any suppliers of the rubber support out there.
Thanks, Barners.
Steve
Highboy34 is offline   Reply With Quote
Old 08-31-2017, 12:06 PM   #2
V8 Bob
V8 Bob's Avatar
Default Re: 49-53 Truck Engine Pan Support
The '48-'52 truck oil pans have a bracket on the bottom of the sump that bolts directly through the starter plate and cast half bell, giving more support. The '53 truck uses a full cast iron bell housing that has no connection to the oil pan.
The '49-'50 (and some early '51) Mercurys did have an angle bracket attached to the starter plate that connects to three studs on the bottom of the oil pan.
In both cases, there was no rubber pad that I'm aware of. There is a rubber dust seal that runs along the top of the Merc starter plate, and an alloy/rubber seal that tucks between the pan and indented truck starter plate.
V8 Bob is offline   Reply With Quote
Old 08-31-2017, 05:39 PM   #3
Ken Crans
Ken Crans's Avatar
Mac Van Pelts has both rubber gaskets.
Ken Crans is offline   Reply With Quote
Old 08-31-2017, 05:45 PM   #4
Ross F-1
Ross F-1's Avatar
That's a separate dust shield that has the rubber
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 08-31-2017, 05:50 PM   #5
Ross F-1
Ross F-1's Avatar
This is the bracket OP is referring to. It's welded solidly to the pan and as Bob said, the clutch cover/starter plate bolt to it. No rubber.
