Old 03-12-2022, 03:56 PM   #1
Veeder
Default 41 stock lower radiator hoses V8
Just curious has anyone had any problems with some of the “ford script” lower radiator hoses. This is not a problem I can’t resolve without better clamps and some Indian head sealant but doesn’t be seem like I should have to. The hose in my opinion are not curved properly and the connection on the pump side wants to work it’s way off.
Again I will deal with this just wondering if many people have run across the same issue.
Bob
Veeder is offline   Reply With Quote
Old 03-12-2022, 05:11 PM   #2
Newc
Newc's Avatar
Default Re: 41 stock lower radiator hoses V8
On my '48 I noticed that those hoses can be reversed, but then do not fit right. Newc
Old 03-15-2022, 07:45 AM   #3
Neal Garland
If the hose connection "snouts" on the water pumps have been painted they will be slippery and the hoses will have a tendency to slip off. Had that problem on my 41 sedan.
Neal Garland is offline   Reply With Quote
Old 03-15-2022, 03:21 PM   #4
19Fordy
19Fordy's Avatar
I found that dimpling the water pump snouts with a center punch provides a good "bite" for the hoses. Plus, use two clamps if possible. My lower hoses are made of chrome plated copper tubing secured by two hose clamps and a short piece of hose at each end.
The type of clamp used makes a big difference in providing uniform clamping pressure. Take a look here:
https://www.google.com/search?q=what...hrome&ie=UTF-8
