12-27-2021, 04:42 PM | #1 |
52 merc crank in 8ba block
I have all the parts for a merc motor just no block (frozen motor long ago) i think i can put the crank in a 8ba block , will there be any problems ?
thanks kurt |
12-27-2021, 04:44 PM | #2 |
Re: 52 merc crank in 8ba block
crank casting no k1208
kurt |
12-27-2021, 05:00 PM | #3 |
blocks/con rods are the same pistons are merc specific to use with 4" throw on the crankshaft
12-27-2021, 05:47 PM | #4 |
All 8BA family blocks are basically interchangeable as was mentioned even though they sometimes have some minor differences. The only difference in a 1952 crank and the ones prior to 1951 is the capability to fit a torque converter & automatic transmission.
12-27-2021, 05:53 PM | #5 |
You can also put it in a 59AB block.
12-27-2021, 08:04 PM | #6 |
Owner/Operator of 'Jailbar Ranch' on the side of Mt. Pickett. Current stable consists of 1946 1/2 ton pickup turned woodie wagon with FH V8, 1947 Tonner Pickup (red) mostly stock with exception of a cummins 6at turbo diesel, 1946 Tonner Pickup (green) with 226 cu in 6 cyl flathead, 1979 Toyota landcruiser wagon, completely encased in 1947 Ford Jailbar sheet metal. Ok, cornbinder rear fenders..... 'Rusty ol' floorboards, hot on their feet' (Alan Jackson) |
12-27-2021, 09:11 PM | #7 |
The crank should fit all 2.498 Blocks made from late 38 up. and even the 36Lb up when turned down to 2.398. These blocks may need alittle clearance for the rods.
12-27-2021, 09:41 PM | #8 | |
kurt .....Just to be perfectly clear, there is NO DIFFERENCE between a Ford & a Mercury bare block manufactured between 1948 (trucks) and 1953. They're ALL the same cast block! Only difference (internally) is the crankshaft, pistons & camshaft. DD . |
12-28-2021, 08:47 AM | #9 |
Thanks everyone thought i might need to relieve bottom of cyl, seems that i don't.
thanks kurt |
