07-30-2012, 07:52 PM | #1 |
302 ford oil pan help
I have a 1983 302 going in a 64 econoline van and wish to convert the oil pan to a rear sump pick up .....What will work??? mustang 302 or 351. I hear some have rear sump systems ,just don't know what will work ..Help
thanks John |
07-30-2012, 08:30 PM | #2 |
Re: 302 ford oil pan help
You will need a rear sump 302, the 351 pan has a larger rear main. Look at an Explorer 302 pan. You will need the respective oil pick up tube and a cap screw for one of the main bearing caps to mount the rear sump pick up. It is all a bolt in operation. I just did the reverse, put a front sump pan on an Explorer 302 for my 60 wagon. The pan and pick up are gone to a fellow rodder that is installing a 302 into a 36 Ford (took out the "dark side" engine)
Bill, certified Ford nut. 2016 F-150 2016 Focus 08 Shelby GT500 57 Ford Ranchero 36 Chevy, 351C/FMX, 8", Mustang II |
07-31-2012, 06:39 PM | #3 |
I was suspect of the 351 just didnt know for sure..302 explorer ???year??? any other 302 maybe mustang fox body??? Year ???
08-01-2012, 02:42 AM | #4 |
my 79 ford f100 with a 302 has a rear oil pickup...
08-01-2012, 09:05 AM | #5 |
