Old 06-26-2012, 11:24 PM   #1
JohnSunliner
JohnSunliner's Avatar
Default 1954 Sunliner
I am re-restoring a 54 sunliner. The sun visor brackets on the car wouldn't hold the visors correctly. I thought they must be reversed left to right as were other things I have found. After taking them off I have concluded there is no way they can be installed to work properly. If they were to screw to a roof they would work (swing correctly) but this is a convertible and they screw to the A pillor. So my question, is there a special bracket for sunliner visors? These are probably for a sedan, does a sedan visor bracket screw to the roof? Thanks for any help, new ones are expensive and I want to make sure I got it right before I spend the money.
John
JohnSunliner is offline   Reply With Quote
Old 06-27-2012, 09:34 PM   #2
paul2748
paul2748's Avatar
Default Re: 1954 Sunliner
As far as I know,. the Sunliner, Victoria and Skyliner sun visors were different from the other sedans. However, I don't know the difference. I have a 54 Victoria and if you can post a picture I can compare it to my Victoria.
Old 06-27-2012, 11:27 PM   #3
JohnSunliner
Paul thnaks. Here is the visor I took off the car that will not swing correct,
And this is where they mount on the windshiled frame, this is the right side. there is only one way the three holes will line up and they swing up and down not horizontally. no matter how I manipulate it, I can not get it to work.
[IMG]http://i48.tinypic.com/2q8rl02.jpg[/IMG]
John
Old 06-29-2012, 10:13 AM   #4
paul2748
paul2748's Avatar
John a picture of my visor (54 Victoria). As I mentioned, I believe that the Sunliners, Skyliners and Victorias all used the same visor. However, I can not say positively that is the case. They all used the same windshield, which was different than the other sedans.
There is a web site for 54's ( http://www.1954ford.com ). If you go to the site and ask, they may be better able to help with convertible parts.
The visor in my car is 19 1/2 x 4 1/2
Someone with a sunliner should pop in here and either confirm or refute this.
Paul
Old 06-29-2012, 11:03 AM   #5
JohnSunliner
Thanks Paul. THis convinces me I have the wrong parts. Your type will work in my Sunliner. Looks like I will have these current ones for sale
This is a great web site for sharing information, thanks again!
Old 07-21-2012, 02:23 PM   #6
Gerry
Gerry's Avatar
John did you see the pictures I left of the Sunliner sun visor brackets Gerry
Gerry is offline   Reply With Quote
Old 07-21-2012, 11:03 PM   #7
JohnSunliner
Yes, I did see them. I ordered new ones from MACS. They are expensive but fit perfect. The previous owner put sedan ones on it. Instead of swinging right and left they went up and down!
Thanks!
John Adams
Old 07-22-2012, 08:00 AM   #8
HOTRODPRIMER
HOTRODPRIMER's Avatar
The first photo mounts looks identical to the visors in my Ranch Wagon. HRP
‘When one door closes, another opens. But we often look so regretfully upon the closed door that we don’t see the one which has opened for us.’ Alexander Graham Bell
HOTRODPRIMER is offline   Reply With Quote
