Old 06-19-2012, 06:49 PM   #1
indyhac
Default '54 Motor Mount Location
I took my 256 Merc engine out for rebuild and thought I put the motor mounts back on the same way they were before but the engine won't go back in and line up. I thought that the open end of the "C" shape of the motor mounts was supposed to face the rear, towards the firewall. Can anyone tell me if this is correct?
Thanks, Scott
indyhac is offline   Reply With Quote
Old 06-19-2012, 07:48 PM   #2
Ole Don
Ole Don's Avatar
Default Re: '54 Motor Mount Location
Face them as if you are streamlining them, the open part to the rear. The studs are a little long though, it helps to saw a half inch off the studs while the mounts are still in your hands. They slide in the holes better that way.
Ole Don is offline   Reply With Quote
Old 06-19-2012, 07:52 PM   #3
Ole Don
Ole Don's Avatar
Also, never keep the dizzy cap tight while you put the motor in. It will get cracked every time.
Old 06-19-2012, 08:59 PM   #4
indyhac
O.K., thanks; I thought that I had them facing the right way. However, I'm missing somethin' here. What the heck is the dizzy cap?
Old 06-19-2012, 09:36 PM   #5
parklane
parklane's Avatar
Distributor cap.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 06-19-2012, 09:54 PM   #6
Daves55Sedan
Daves55Sedan's Avatar
The way I always did it, I installed the motor mounts to the frame then lowered the engine down on top of them. Its a little harder to get the holes lined up, but its better than taking a chance on tearing up the motor mount threads if you tried to do it the other way.
Old 06-20-2012, 10:04 AM   #7
indyhac
Dizzy cap = Distributor cap?
Old 06-20-2012, 11:03 AM   #8
Ole Don
Ole Don's Avatar
Yes, an Aussie term I picked up. I thought it nearly universal now.
Old 06-20-2012, 03:51 PM   #9
streetdreams
Location: Howell, Michigan, USA, The Peoples Slightly Overspent Demodependancy of Michigan
The only thing Aussie I pick up now and then is a 12 pack of Fosters........
streetdreams is offline   Reply With Quote
Old 06-20-2012, 04:48 PM   #10
Ole Don
Ole Don's Avatar
I was there in 1995. I dont rememebr what they were feeding us, but it sure was good! I do remember eating 'roo steak. Out of this world good stuff!!!
Old 06-20-2012, 09:23 PM   #11
rick55
rick55's Avatar
Yep, we have different names for everything, bonnet,boot,mudguards, comes from being colonial boys descended from convicts I guess. God Bless Old Blighty!
Pity they never really grasped the V8 til they got hold of the aluminum V8 they put in Rovers.
And yep, we sure love our beers. It is possible to get in a fight if you don't like the local brews. Our beer seems to bring out the best in folk.
Regards
Rick
West Australia
1958 Ford Mainline Utility, 1955 Ford Tudor Sedan
Anyone who stops learning is old, whether at twenty or eighty. Anyone who keeps learning stays young. The greatest thing in life is to keep your mind young.
Henry Ford
rick55 is offline   Reply With Quote
Old 06-21-2012, 01:00 AM   #12
Y-Blockhead
Y-Blockhead's Avatar
Must be from all that Vegemite...
Old 06-21-2012, 06:02 AM   #13
rick55
rick55's Avatar
I never found out til recently that Vegemite is actually a byproduct of the brewing process.
It puts lead in your pencil.
Regards
Rick
West Australia
Henry Ford
Old 06-21-2012, 09:58 AM   #14
indyhac
Thanks to you guys for your help! I got it bolted in yesterday. I put the mounts in the frame slots, lowered the motor down, yelled at it a few times, and finally got the bolts through the upper motor mount holes and screwed into the block. In retrospect, I should have opened up the upper holes in the motor mounts about 1/32" larger which would have made it easier; not much clearance in the original holes, meaning the motor and mounts have to be aligned well to get those bolts in.
I sold my '47 Plymouth coupe to a guy in Narrawalle, New South Wales last year. Took a long time for him to get all the forms and paperwork taken care of.
Won't do anything like that with my Mercury; it's going the be in my estate sale!
Old 07-08-2012, 01:33 PM   #15
Motorhead6
Another trick is to leave the bolts in the block loose so that the mounts sort of flop. This makes it easier to get the studs inserted into the frame as they will move around. This way, you don't have to stand on your head to get the bolts started into the block.
Motorhead6 is offline   Reply With Quote
Old 07-11-2012, 10:38 AM   #16
indyhac
Cool Re: '54 Motor Mount Location
Good Idea. Now why didn't I think of that!
