09-08-2012, 08:10 AM | #1 |
Ford steering shaft
City:
Palm City
State:
Fl
I need a length of ford steering shaft with the taper and keyway, to graft on to a 37 hudson box I recenly found for my 32. It doesnt need to be much more than a foot long or so. Thanks, Rich
09-09-2012, 04:41 AM | #2 |
Re: Ford steering shaft
You can get it from Speedway
09-09-2012, 09:11 PM | #3 |
if you will fill me in on that cool cross member in that 29 frame, I will send you shaft piece that you need.
09-10-2012, 01:32 PM | #4 |
Flatmotor 40, the one speedway sells is a stepped straight shaft with a keyway for a T wheel. Plus no hole thru the center for the horn wire Thanks for thinking of me! Rich
09-11-2012, 07:43 AM | #5 |
