Old 09-09-2021, 09:39 AM   #21
Roger V
Roger V's Avatar
Default Re: Four Post Lift Recommendations….
My main recommendation is the four post lift should have collars around the posts at the end of the crossbars (not inside the posts). If the lift cants for any reason, it could collapse. This is particularly important if the four posts are not anchored to the floor.
Roger V is offline   Reply With Quote
Old 09-09-2021, 11:26 AM   #22
LeonardS
Have you had this happen? I have had 7 of the 4 post lifts with the crossbars inside the posts. I’ve not seen any indication of a problem and none have been anchored down.
LeonardS is offline   Reply With Quote
Old 09-09-2021, 11:41 AM   #23
griffin
We had a "situation" once where a car was being let down and one of the locks caught, while the other three were free. The car was leaning as seen in various ads and if allowed to be lowered much further, it could have been disastrous.
It was a combination of mechanical failure and user inattention.
griffin is offline   Reply With Quote
Old 09-09-2021, 12:02 PM   #24
LeonardS
I think that could happen with either style lift.
Old 09-13-2021, 04:21 PM   #25
holdover
I bought a trolley jack and can do all that you mentioned. Works by air over hyd. and has safetys built it that locks it in the desired height position, it automatically locks in place on the rails when it is being used.
holdover is offline   Reply With Quote
Old 09-14-2021, 10:16 AM   #26
katy
katy's Avatar
Got a link? or a picture?
Old 09-14-2021, 10:58 AM   #27
SwampLedge
Here you go, katy.
https://www.advantagelifts.com/produ...k-air-operated
SwampLedge is offline   Reply With Quote
Old 09-14-2021, 11:39 AM   #28
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Just to muddy up the waters a little, we are considering a single post lift that is portable where we can use it in many areas of the shop. Technology in the lift industry has really changed over the years. Now the rage is a single column lift that is mobile much like a pallet jack. You move the jack around your garage (-or into the driveway) and you roll it under the vehicle. Then you swing the arms out and lift the vehicle. These things are strong enough to lift diesel pick-ups too. Very stable although it would not seem like it.
Granted, these are not going to be for everyone, but for the hobbyist that would like to have a lift to maintenance their vehicles in different locations (-especially those who must work outside in the driveway), this is a great option. Here is a link to one brand...
https://www.asedeals.com/workhorse-s...SABEgLpGvD_BwE
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 09-14-2021, 11:46 AM   #29
LeonardS
The lifting capacity is 6,000 lbs, so I don’t think that’s enough to lift 3/4 ton or 1 ton diesel crew cab 4x4’s like most guys are buying. It does look handy for cars and light duty trucks.
Old 09-14-2021, 04:41 PM   #30
Chris Haynes
Chris Haynes's Avatar
Originally Posted by mercman from oz View Post
Ouch - not good!!!
Looks like faulty concrete.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 09-14-2021, 04:43 PM   #31
Chris Haynes
Originally Posted by trulyvintage View Post
Did you post over on the MTFCA Forum ?
Freight is expensive - buy one close.
Don’t buy used.
Hire someone with experience to install it.
Jim
I was lucky. The manufacturer was close by. The installer picked it up.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 09-14-2021, 04:47 PM   #32
Chris Haynes
Originally Posted by 51504bat View Post
See post number 8 regarding a trolley jack.
Fine if you only want to lift the front OR rear. I prefer to have complete accessibility without having to move a jack from one end to the other. You also need a building that would support as trolley jack.
1921 Runabout
1930 Tudor
Early 1930 AA
Old 09-14-2021, 04:50 PM   #33
Cpuckett
Originally Posted by Keith True View Post
Am I really seeing one inch of concrete under that lift? Nothing on that lift gave way, that one was the floor under it. A garage here in town has gotten many years out of his Mohawk lifts.
It that 🤷
Cpuckett is offline   Reply With Quote
Old 09-14-2021, 05:11 PM   #34
Late model
Late model's Avatar
Same problem. Getting just too hard to get down and up from a creeper.
Just bought and installed an Advantage lift about three months ago. Quality is good. Welds seemed good, and paint is good. I have been very pleased with it so far.
Two of my friends helped (or I should say I helped two of my friends) install it in a day. Built it outside and rolled it in on it's rollers.
Look at the install video.
Instruction manual is OK, but had a few head scratching errors.
I lifted my 1955 Chrysler Imperial with no problem.. Slow (as all the four posts are), but fast lowering.
I would not hesitate to buy another Advantage four post again.
Late model is offline   Reply With Quote
Old 09-15-2021, 10:14 AM   #35
katy
katy's Avatar
Originally Posted by SwampLedge View Post
Thanks
Late Model, love your '56
