Old 01-14-2019, 09:28 PM   #1
oldbike99
oldbike99's Avatar
Default Advise for installing camshaft timing gear
As the title says, I am looking for advise on installing the new gear on the camshaft of my Model A. Pressed on, tapped on?
Thank you in advance.
oldbike99 is offline   Reply With Quote
Old 01-14-2019, 10:25 PM   #2
MAG
MAG's Avatar
Default Re: Advise for installing camshaft timing gear
It is lightly tapped on.
I noticed the harder I work the luckier I get!
MAG is offline   Reply With Quote
Old 01-15-2019, 09:24 AM   #3
George Miller
George Miller's Avatar
The cam gear has a big nut holding it on, takes a special wrench to take it off.
George Miller is offline   Reply With Quote
Old 01-15-2019, 09:49 AM   #4
jhowes
Also the torque on that big special nut is a bit of a mystery. I'd swear I read somewhere that it is 100 ft lb. but I can't find it now. Also you can order a modern 6 faced nut from the venders. It is cheaper than the special wrench that the originals take Jack
jhowes is offline   Reply With Quote
Old 01-15-2019, 12:09 PM   #5
katy
katy's Avatar
It's inside the front of Bratton's catalogue.
Old 01-15-2019, 12:19 PM   #6
Dick Steinkamp
Dick Steinkamp's Avatar
I've taken the stock nut off with a brass drift and a BFH.
All steel from pedal to wheel
Dick Steinkamp is offline   Reply With Quote
Old 01-15-2019, 08:01 PM   #7
oldbike99
oldbike99's Avatar
My question is how much force is required to install the new gear on the camshaft? Any precautions?
Old 01-15-2019, 09:16 PM   #8
PC/SR
Very little force is required to fit the gear to the camshaft. It might even just slip onto the dowels. Otherwise, gentle tapping.
PC/SR is offline   Reply With Quote
Old 01-15-2019, 09:59 PM   #9
Purdy Swoft
Purdy Swoft's Avatar
I can usually slip the cam gear over the cam dowels by hand . There is a slight off set to the cam dowels . The gear can be forced over the dowels wrong so care needs to be taken . I use the hex nut that is listed in Snyders catalog . I don't think that Ford listed torque values for model A bolts or nuts . I think that 100 ft. lbs . torque on the cam nut is a bit excessive . I just use common sense when tightening . Though I have done it before, I don't recommend using a rag between the timing gears to keep them from turning when tightening the cam nut . It is best to remove the side timing cover and use a clamp and wood blocks to hold the cam gear from turning . The rag method puts strain on the gear teeth . If the rag method is used with a fiber cam gear , the gear usually fails quickly . For longer timing gear life , I prefer to use either the bronze or aluminum cam gear .
Old 01-15-2019, 11:25 PM   #10
Bud
Bud's Avatar
I have also tried to find where the 100 ft-lbs came from and could not find the source. The nut is only about .41 thick. The thread diameter is 1.00". In my opinion if you go over about 70 to 75 ft-lbs you may strip the threads off the nut.
Bud is offline   Reply With Quote
Old 01-17-2019, 04:39 PM   #11
jerry tocci
I did mine by removing valve springs and placing a mirror against radiator and hand crank for alignment
jerry tocci is offline   Reply With Quote
Old 01-17-2019, 06:06 PM   #12
Dick Steinkamp
Why would you remove the valve springs?
Old 01-17-2019, 09:16 PM   #13
Smooth_One
Smooth_One's Avatar
I was wondering this myself?
Isaiah B.
1928 all metal Tudor
Smooth_One is offline   Reply With Quote
Old 01-21-2019, 12:04 PM   #14
Dan McEachern
There is absolutely no reason to torque the cam nut to 100 ft-lbs or even 75 ft-lbs. Where this cam from, I have no idea, but if it is in Bratton's catalog, I wish they would fix it. The advise to use a clamp on the rim of the gear is what I always recommend to anyone changing a gear in the car.
Dan McEachern is offline   Reply With Quote
