Old 03-22-2012, 09:37 AM   #1
30six
30six's Avatar
Default 36 headlight wiring harness
I'm preparing to replace the headlight harness on my 36.
Will there be a problem pulling headlight socket pigtail through headlight stands or should I remove lights to feed through?
I tried pulling old wiring out and it's not moving.
Thanks!
30six is offline   Reply With Quote
Old 03-22-2012, 05:32 PM   #2
Terry,OH
Terry,OH's Avatar
Default Re: 36 headlight wiring harness
There is a problem, the three wires are the same length and three terminals will not fit through the hole at the same time. I cut two of the terminals off and then pull the harness in using a string through the hole to assist, then resolder the two terminals, but make each one shorter than the next in case they have to come out.
Old 03-23-2012, 05:39 AM   #3
30six
30six's Avatar
Post Re: 36 headlight wiring harness
Terry: thanks, will try it by cutting end as you suggested.
