05-18-2018, 05:31 AM | #1 |
Houdaille shock pressure
My right rear shock arm on my 41 sedan is angled down some, not in almost horizontal position like others, about 3" down at end by link. I tried to move it back up and it will not move like there is too much pressure. Is there any way to remove pressure to get arm back to where it should be?
Photo attached with car jacked up at right frame. Last edited by 30six; 05-18-2018 at 06:12 AM. Reason: adding photo |
05-18-2018, 06:55 AM | #2 |
Re: Houdaille shock pressure
Did you disconnect the shock? It look bound up on all the linkage.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
05-18-2018, 07:12 AM | #3 |
Seem to recall from back in my stock car racing days that the shocks could be locked up by rotating this pressure adjustment. Perhaps it needs attention.
DON'T RECALL DOING SOMETHING FOR MYSELF BASED ON SOMEONE ELSE'S LIKES OR DISLIKES Last edited by 51 MERC-CT; 05-18-2018 at 07:25 AM. |
05-18-2018, 07:24 AM | #4 |
Did not disconnect, just jacked car up at frame to connect wire at brake light.
05-18-2018, 07:27 AM | #5 |
George, now that I've seen a photo of what you have, it's apparent the shock link is defective. I'd suggest you remove the shock and the link. That way you can readily determine if the shock is in good functioning condition as well as replace the link.
I'm probably have a link for you.
05-18-2018, 07:41 AM | #6 |
05-18-2018, 07:41 AM | #7 |
As stated, try rotating the pressure adjuster to see if the pressure will release.
05-18-2018, 07:44 AM | #8 |
Did you try to rotate the pressure adjuster?
05-18-2018, 07:47 AM | #9 |
That is my next step once I get back into garage this morning.
I have car home this weekend to complete soldering diode to wires from post earlier this week. |
05-18-2018, 08:42 AM | #10 |
FIXED THANKS! Took shock off and reset link in place.
Thread Tools | |
Display Modes | |
