06-02-2021, 02:05 PM | #1 |
Battery gauge
On my 39 ford deluxe the battery gauge has an ‘n’ between the H at the top and the C at the bottom. The owners manual doesn’t explain what the N stands for. Is it for normal
06-02-2021, 02:41 PM | #2 |
Re: Battery gauge
Do you mean the temperature gauge? If yes, my '39 pickup has the same and my experience is that is about where the stock thermostats would open (160 I am pretty sure) so yes I would call that an N for normal.
06-03-2021, 09:53 AM | #3 |
Re: Battery gauge
No, it’s the battery gauge
06-03-2021, 10:03 AM | #4 |
Re: Battery gauge
Here is my 39 Merc gauge, as you describe BUT with an "L" for "low" and not a "C" as you describe. "H" for "HIGH" and "N" for "normal" and the needle "should" be "around" the "N" with a slight move toward the "H" as the engine revs up.
06-03-2021, 10:07 AM | #5 |
Re: Battery gauge
Here is a 39 Deluxe gauge cluster.Yes N is normal operating range.On the bottom is an "L",not "C".
06-03-2021, 11:04 AM | #6 |
Re: Battery gauge
Thanks again |
