Old 05-18-2018, 05:31 AM   #1
30six
30six's Avatar
Default Houdaille shock pressure
My right rear shock arm on my 41 sedan is angled down some, not in almost horizontal position like others, about 3" down at end by link. I tried to move it back up and it will not move like there is too much pressure. Is there any way to remove pressure to get arm back to where it should be?
Photo attached with car jacked up at right frame.
30six is offline   Reply With Quote
Old 05-18-2018, 06:55 AM   #2
Frank Miller
Frank Miller's Avatar
Default Re: Houdaille shock pressure
Did you disconnect the shock? It look bound up on all the linkage.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound
Frank Miller is offline   Reply With Quote
Old 05-18-2018, 07:12 AM   #3
51 MERC-CT
51 MERC-CT's Avatar
Seem to recall from back in my stock car racing days that the shocks could be locked up by rotating this pressure adjustment. Perhaps it needs attention.
Old 05-18-2018, 07:24 AM   #4
30six
30six's Avatar
Did not disconnect, just jacked car up at frame to connect wire at brake light.
Old 05-18-2018, 07:27 AM   #5
Kube
Kube's Avatar
George, now that I've seen a photo of what you have, it's apparent the shock link is defective. I'd suggest you remove the shock and the link. That way you can readily determine if the shock is in good functioning condition as well as replace the link.
I'm probably have a link for you.
Old 05-18-2018, 07:41 AM   #6
30six
30six's Avatar
Mike: Will remove this morning and see what happens next. The shocks were rebuilt before I purchased the car.
Old 05-18-2018, 07:41 AM   #7
34PKUP
34PKUP's Avatar
As stated, try rotating the pressure adjuster to see if the pressure will release.
34PKUP is offline   Reply With Quote
Old 05-18-2018, 07:44 AM   #8
51 MERC-CT
51 MERC-CT's Avatar
Did you try to rotate the pressure adjuster?
Old 05-18-2018, 07:47 AM   #9
30six
30six's Avatar
That is my next step once I get back into garage this morning.
I have car home this weekend to complete soldering diode to wires from post earlier this week.
Old 05-18-2018, 08:42 AM   #10
30six
30six's Avatar
FIXED THANKS! Took shock off and reset link in place.
