12-06-2021, 09:51 AM | #1 |
od trans id
can anybody help id an overdrive transmission
the tag on it reads 1A3-L main case reads T85C-1A thanks, Kenny |
12-06-2021, 10:34 AM | #2 |
Re: od trans id
Maybe this one.
12-06-2021, 12:03 PM | #3 |
Re: od trans id
Ford used the T-85 starting with the 1949 Lincoln cars. It's a heavy duty 3-speed with the R11 overdrive. Ford used it clear up into the early 70s but the later ones had the nodular case and were referred to as the T-85 R11N. There were several input shafts depending on the application.
12-06-2021, 03:02 PM | #4 |
Re: od trans id
What I am trying to determine is the year so I know if it is 6 volt or 12 volt
Thanks, Kenny |
12-07-2021, 09:20 AM | #5 |
Re: od trans id
https://www.fifthaveinternetgarage.c...rive_parts.php |
