Old 02-17-2019, 10:04 AM   #1
EJ
Default Cool running
Regardless of how long I have been running or the terrain travelled winter or summer when I stop my engine goes cold very quickly probably 20 mins half hour, I'm never sure whether to use the choke or not when I want to restart. It's not causing me a problem and my engine is running fine, I was just wondering if anyone else had the same thing or is that the way it is with the A.
EJ is offline   Reply With Quote
Old 02-17-2019, 10:18 AM   #2
Ray in La Mesa
Default Re: Cool running
I think how quickly the atomized gas condenses out, in the induction system, after the engine is shut off, and your carb/induction configuration, is what you're dealing with. It varies from engine to engine. On my newly rebuilt engine with performance cam, 6:1 head & twin side by side "B" carbs (stock intake w/ second 90 degree elbow braised on for second carb), I can Start the engine w/o choking for only I-2 minutes. On an older totally stock engine it could sit for up to 10 minutes & restart w/o choking. Ambient temp. probably has something to do with it too.
Run a few test starts with different time delays to see what your parameters are.
Ray in La Mesa is offline   Reply With Quote
Old 02-17-2019, 10:24 AM   #3
katy
katy's Avatar
Try 1/2 choke.
Play it again Sam.
Old 02-17-2019, 10:25 AM   #4
EJ
Thanks Ray will give it a try.
Old 02-17-2019, 10:27 AM   #5
EJ
Thanks Katy, I only use half choke when ever I start but thanks for the input.
Old 02-17-2019, 12:34 PM   #6
Purdy Swoft
Purdy Swoft's Avatar
Just a quick touch of full choke is the way that I always crank mine . Too much choke and it can flood . After all it is an updraft setup .
Old 02-17-2019, 01:04 PM   #7
WHN
I also start our car this way. Fresh tune with new plugs, or in need of adjustment. Has always needed a quick choke. Enjoy.
WHN is offline   Reply With Quote
Old 02-18-2019, 03:27 AM   #8
Tom Wesenberg
Tom Wesenberg's Avatar
I always use a 180* thermostat, and never have to use the choke unless the engine is stone cold, which takes hours. I never drive my Model A's in cold weather, which is 40* or less.
Old 02-18-2019, 09:00 AM   #9
old31
Ray do you have a pic of your carb set up, sounds interesting.
Old 02-18-2019, 03:58 PM   #10
Ray in La Mesa
Haven't figured out how to post pictures yet, any instructions?
Old 02-18-2019, 09:25 PM   #11
Tom Wesenberg
I click on.......... "GO ADVANCED"
Then click on.... "MANAGE ATTACHMENTS"
Click on Browse, find your picture, click on it, then Upload your picture.
Old 02-19-2019, 10:38 AM   #12
Ray in La Mesa
Thanks
Thread Tools
Display Modes
