Old 06-21-2012, 10:55 AM   #1
46Ford4dr
46Ford4dr's Avatar
Default 1947 Straight 6 resources
So I have been searching and searching the net for parts for this motor, and 99% of what I am finding is for the V8's (such as this forum). Anyone have any suggestions on straight 6 forums or suppliers for parts? I'm kind of scratching my head over here because nobody seems to have everything I'm looking for and I don't like to order stuff piece by piece. Thanks for the help!
46Ford4dr is offline   Reply With Quote
Old 06-21-2012, 11:39 AM   #2
Bob C
Default Re: 1947 Straight 6 resources
Check this link.
http://www.kanter.com/p30-fon.html#fo7
Bob
Old 06-21-2012, 12:03 PM   #3
41ford1
41ford1's Avatar
Take a look at www.fordsix.com. There is a vintage engine section in the forum there. Joblot shows a lot for the sixes. You may want to check the napaonline site. It's surprising what thay can provide.
41ford1 is offline   Reply With Quote
Old 06-21-2012, 12:07 PM   #4
Bruce Lancaster
Joblot, vendors that have some NOS stashed like C&G Ford and Carpenter, and probably talk with Dick Spadaro on here. The stuff is around but is generally not in the catalog because of low demand.
Ford produced a good ovehaul manual if you 6 is the G type with front distributor. If H type I think bulletins anf the '49 type manuals will cover your needs pretty well.
Bruce Lancaster is offline   Reply With Quote
Old 06-21-2012, 02:04 PM   #5
46Ford4dr
46Ford4dr's Avatar
I appreciate the links guys. I finally found a gasket kit through Egge. I couldn't add it to my cart, that's why I thought they didn't have it. Called, and sure enough, they did!
Old 06-21-2012, 02:16 PM   #6
Newc
Newc's Avatar
Hi ;California Bill, had a chapter on hopping these up in the red and white book on V8 speed. I had a 254" M series six that is the same externally, optional in F6 trucks 49-51. 'Bill' had it bored and stroked to 304" in his book. newc
Old 06-21-2012, 04:44 PM   #7
Henry/Kokomo
Henry/Kokomo's Avatar
MACs has some 6cyl parts.
Henry/Kokomo is offline   Reply With Quote
Old 06-22-2012, 01:27 AM   #8
meric42
meric42's Avatar
I have a supply of NOS Ford 6 engine parts if you are interested.
Rings, Bearings, Valves etc
Let me know what you need
I need an 01A 1453 Brkt Spare wheel hold down for my sedan delivery - PLEASE HELP
Gotta love my '42 Sedan Delivery's - Now that I own the only two in New Zealand
http://www.fordbarn.com/forum/album.php?albumid=580
meric42 is offline   Reply With Quote
Old 06-22-2012, 05:37 AM   #9
39wdy
Hi, I have an original Ford Repair Manual for the 6 cylinder G series engine. It is manual 3694 with the green cover, dated December 15, 1946. It is in mint condition and if you could use it please send me your mailing address and I will send it to you. My e-mail is [email protected] Best wishes, Toby
39wdy is offline   Reply With Quote
Old 06-22-2012, 06:56 AM   #10
Ken/Alabama
Ken/Alabama's Avatar
What you looking for ? I have a bunch of G series 6 cyl parts
Ken/Alabama is offline   Reply With Quote
Old 06-22-2012, 07:15 AM   #11
amodel25
amodel25's Avatar
I bought everything to rebuild my '51 "H" series six from Kanter. It was all new old stock in the original boxes, no import crap.
amodel25 is offline   Reply With Quote
Old 06-22-2012, 07:31 AM   #12
46Ford4dr
46Ford4dr's Avatar
Newc, I'll have to look into that. I'm not going to hop it u[p for now. I'm trying to do this with very little cash. I plan on using my resources and doing research and spending more time than money right now. I'm not worried about speed, just worried about going and stopping. Doesn't matter how fast I go, as long as I can stop. hahaha
Henry, I ordered a MACs catalog a few weeks ago, still waiting on it. But I have been browsing online.
Meric, I don't know if I'm going to get that far into the motor right now. Maybe eventually. But I'd like to see if I can get it to run as is. BUT, I hate to pass up NOS Ford parts. Can you please shoot me a PM with what you have, and maybe a price on what you want for them. I wonder if shipping will kill me.
39wdy, email will be sent as soon as I'm done replying here. Much appreciated. I've been looking for one.
Ken, I'll shoot you a PM. At this point I know I need gaskets, which I will most likely order from Egge. And then maybe a fuel pump, water pump, thermostat housing, and who knows what else as I go along here.
amodel, seems like "H" series are much more popular. Hunting for G parts is an Easter egg hunt.
Old 06-22-2012, 09:01 AM   #13
46Ford4dr
46Ford4dr's Avatar
Also, does anyone have an actual picture (not a diagram), or know where I can find one, of a close up view of the top of the motor with the head off? When I took the head off, the water passages were clogged, but because its been sitting so long, its kind of hard to get the stuff out. So in order for me to see what needs to be removed, I'd like to see what the water passages are supposed to look like.
I know that since it has been sitting for so long,t hat I should take it completely apart, but I just dont have the $ for that right now. And I have been assured by several people who looked at it, that said to flush all that stuff out, and it should run.
My instinct is to completely tear it down, but I have only really worked on "newer" 70's and above small block Chevy/Fords/Mopars or big blocks, all of which were being built for power, never to just "get something running". I know it doesnt matter what make/model a motor is, that if it has been sitting so long, that it should be redone. But I have seen many a guys get motors running after years with very little work done to them other than a little cleaning and flushing. So I'm basically arguing with myself on whether to just clean it up inside a bit, then flush it out, do a few new gaskets, put fluids in, and crank her over. OR, to tear it down. This is a budget build (for now), so I'm hoping some of you will be able to give me some advice.
Old 06-22-2012, 11:29 AM   #14
Clem Clement
Clem Clement's Avatar
use a pick and a magnet to pull the rust junk out. Air pressure to blow stuff out as well. Open and remove the block drain plug and give that hole some air.
I this a great board or what!. Lots of help here for sure!!!
Clem Clement is offline   Reply With Quote
Old 06-22-2012, 11:38 AM   #15
46Ford4dr
46Ford4dr's Avatar
Clem, I agree! It definitely is an awesome board! Way more help than other forums that I have been on! Thanks!
Old 06-22-2012, 02:06 PM   #16
1936ford64
If you get tired of working on it, I have one with less than 22,000 original miles. In my truck and purrs like a kitten. Don 541-582-8966
1936ford64 is offline   Reply With Quote
Old 06-23-2012, 05:55 AM   #17
Chuck Kuntz
I have some NOS genuine Ford parts for that motor---gaskets, rings, pins, pistons, bearings, rings, valves etc. Very cheap.
Chuck
Chuck Kuntz is offline   Reply With Quote
Old 06-23-2012, 06:22 AM   #18
turnpikecrusier
I used a long screwdriver to stick down the water passages and bust up the gunk, then made me an adapter for my shop vac with a 1/2 inch clear hose . sucked all the stuff out, put it back together. ran it for a whole then flush out a couple of times all good now. Smiley
turnpikecrusier is offline   Reply With Quote
Old 06-23-2012, 09:49 AM   #19
Ken/Alabama
If I remember correctly on that 6 cyl when you remove the water pump there is a long baffle that can be removed . Its purpose was to carry the water to the rear of the engine Im guessing .
Old 06-23-2012, 10:33 AM   #20
Bob C
Rock auto has the gasket set for $66.79.
Bob
Thread Tools
Display Modes
