Old 11-27-2018, 03:01 PM   #1
FlatheadTed
FlatheadTed's Avatar
Default Drake shocks and Sway Bar kits
We are wanting to fit a full set of Drake shock kits with the rear sway bar to a 39 Merc ,looking for the easiest option of his selections, like shackle mount or perch mount . opinions appreciated .
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 11-27-2018, 07:47 PM   #2
TJ
TJ's Avatar
Default Re: Drake shocks and Sway Bar kits
if you have a '39 Merc I would make sure a Ford shock kit and sway bar will fit. to my knowledge the frame on a '39-'40 Merc is very different from a Ford frame.
Old 11-27-2018, 09:14 PM   #3
FlatheadTed
OK TJ thank you ,good advice .
Old 11-27-2018, 09:18 PM   #4
39portlander
39portlander's Avatar
I put the kit on my 39 P/U and very happy with the fit and finish. I spoke with a fella in their tech dept. before I bought and after the conversation about my application based on the components claims for a truck I placed the order.
The directions were great and on my truck it was a good project start to finish, let us know how you make out.
I did change the shipped shocks in the kit with air shocks and that was the way to go for my application. You want those shocks to work @ there mid-point, the adjustable air shocks I set for about 45 psi are perfect for my 1/2 ton stance and the really great roads we have here in new england
39portlander is offline   Reply With Quote
Old 11-27-2018, 09:23 PM   #5
slowforty
slowforty's Avatar
I have Drakes' Sway bar kit on my 40 Sedan. It works well. I dont know if the Mercury rear ends are wider than the Fords.
slowforty is offline   Reply With Quote
Old 11-27-2018, 10:47 PM   #6
Phil Gillespie
Phil Gillespie's Avatar
Ted you might also try Chassis Engineering, I got a front set and sway bar for 39 Standard. It was a great bolt on unit with good results.
Phil NZ
Phil Gillespie is offline   Reply With Quote
Old 11-27-2018, 11:04 PM   #7
Marvin/TN
Send a message via AIM to Marvin/TN
Did not Chassis Engineering close or did someone buy them out? I have their shock kit on the front my 46 coupe. It uses the spring shackle as the lower mount
Marvin/TN is offline   Reply With Quote
Old 11-28-2018, 09:51 AM   #8
tubman
tubman's Avatar
Chassis Engineering was bought out by someone, I think it was Heidt's. There is more information on the H.A.M.B. (Which is more of a "Hot Rod" site that the Barn.)
Old 11-28-2018, 10:17 AM   #9
Gary troxel
I thought Speedway was involved.
Gary troxel is offline   Reply With Quote
Old 11-28-2018, 11:26 AM   #10
KGS
KGS's Avatar
Hey Gary, good to see you back! Still have the Stude pickup?
KGS is offline   Reply With Quote
Old 11-29-2018, 03:31 PM   #11
FlatheadTed
ok thanks all
Old 11-29-2018, 08:24 PM   #12
tubman
tubman's Avatar
Wait a minute! THE Gary Troxel? It's not that common a name!
Old 11-29-2018, 10:45 PM   #13
Lanny
Lanny's Avatar
Yep, Gary is,,,Mr Blue
If mama ain't happy, ain't nobody happy.
But if daddy ain't happy...RUN
Lanny is online now   Reply With Quote
Old 11-30-2018, 01:06 AM   #14
deuce_roadster
deuce_roadster's Avatar
My brother was in the same class as Gary at Olympia High School. Name of the group was taken from the telephone exchange in Olympia---FL.
