Old 09-30-2014, 02:13 PM   #1
BILL WZOREK
BILL WZOREK's Avatar
Default Rear end drain location
SHEBA is a 47 Tudor with a 9" ford rear installed. where is the drain?
Or do I have to pull the rear cover ~?~ if that is the case is there a gasket involved ?
GETTING READY FOR THE RUN to the FEST !!!
BILL WZOREK is offline   Reply With Quote
Old 09-30-2014, 02:27 PM   #2
40cpe
40cpe's Avatar
Default Re: Rear end drain location
I don't know what you have, but my 9" axle has a drain in the bottom of the housing for the chunk. It also has a solid, non-removable rear cover because the internals are accessed by pulling the chunk out of the housing.
40cpe is offline   Reply With Quote
Old 09-30-2014, 03:29 PM   #3
George/Maine
George/Maine's Avatar
I can't remember back to the 60s but don't think there is one.
If you want to do some PM replace the wheel bearings they are a dry bearing.
I had a bearing go few years ago, and friend had one go the other day.
George/Maine is offline   Reply With Quote
Old 09-30-2014, 08:02 PM   #4
rustythumb
some have the drain plug in the housing, some in the 3rd member. you must have the housing & pumpkin without. I've been there, had to drill & tap new hole.
rustythumb is offline   Reply With Quote
Old 09-30-2014, 08:42 PM   #5
Talkwrench
Talkwrench's Avatar
Am I missing something a 9" with a cover.. do you mean an 8.8"?
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 10-01-2014, 05:25 AM   #6
BILL WZOREK
Talkwrench:
When I Bought the car I was told it was a 9" it could be a 8.8" for all I know~~
It run's great just trying to do some PM to keep it that way.
Are there any #'s to I D what I have ? and where would they be ?
THANKS
Old 10-01-2014, 05:29 AM   #7
SofaKing
SofaKing's Avatar
A picture is worth a thousand posts...
SofaKing is offline   Reply With Quote
Old 10-01-2014, 05:31 AM   #8
Clem Clement
Clem Clement's Avatar
Can you remove a bottom edge bolt and let the oil run out the bolt hole?
Clem Clement is offline   Reply With Quote
Old 10-01-2014, 06:45 PM   #9
Talkwrench
Talkwrench's Avatar
Bill I hope this quick I.D. might help I had it in my favourites. http://www.drivetrainamerica.com/t-sdl_technical.aspx
Old 10-01-2014, 06:57 PM   #10
Mike in Mass
Mike in Mass's Avatar
Bill I have to admit when I saw the title to your question, I thought, OH BOY ,,,HERE WE GO ! ! ! and I,m sure I,m NOT THE ONLY ONE ! ! sorry thats all I have to contribute to this thread mp
Mike in Mass is offline   Reply With Quote
Old 10-01-2014, 07:42 PM   #11
brake1000
brake1000's Avatar
A quick way to find out what kind rear end you might have. If you can put a socket on the bottom two nuts its a 8'', if you have to use a wrench its a 9''. There are usualy no drain plugs on the housing or punkin, just a fill plug on the left side of the punkin. To drain the grease out of the rear end you have to pull the punkin and replace the gasket, or buy a siphon hose.
Bruce
brake1000 is offline   Reply With Quote
