04-01-2017, 06:38 AM | #1 |
Pertronix 40111 6V 1.5 ohm
Well appears the last around of rain has washed away the broad salt and I have a pertronix 40111 1.5 ohm 6V coil --epoxy filled to try out (suspect my oil filled coil might be my intermittent issue). With this coil, I believe it has a higher output voltage and would my spark plug gaps need changing? I have a standard head (compression wise)
https://m.summitracing.com/parts/pnx...DBMaAqC88P8HAQ
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
