03-31-2021, 05:40 PM | #1 |
80 over rebuild
Anybody out there know where i can get pistons & rings for a 57 312 t bird 80 over.
03-31-2021, 05:47 PM | #2 |
Re: 80 over rebuild
Often wrong but never in doubt. |
03-31-2021, 06:27 PM | #3 |
Re: 80 over rebuild
just wondering what size is your engine now.
03-31-2021, 06:32 PM | #4 |
Re: 80 over rebuild
312
03-31-2021, 06:41 PM | #5 |
Re: 80 over rebuild
03-31-2021, 07:02 PM | #6 |
Re: 80 over rebuild
03-31-2021, 08:15 PM | #7 | |
Re: 80 over rebuild
It's an EDB-E with a January '58 date code if that makes a difference. Some years of blocks may tolerate that amount of over-bore better than others, I don't know. . Last edited by dmsfrr; 04-03-2021 at 09:49 AM. |
03-31-2021, 08:58 PM | #8 |
Re: 80 over rebuild
the early blocks suffered less from core shift.
03-31-2021, 09:22 PM | #9 |
Re: 80 over rebuild
Huh?
04-01-2021, 12:39 AM | #10 |
Re: 80 over rebuild
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
04-01-2021, 06:51 AM | #11 |
Re: 80 over rebuild
My "Huh?" response was to a spam post in what appeared to Russian. The moderator must have removed it. I understand about bore limits and core shift.
04-01-2021, 09:55 AM | #12 |
Re: 80 over rebuild
Then that explains it ...
04-01-2021, 04:12 AM | #13 |
Re: 80 over rebuild
checking between the cylinders the old blocks were more even.less cylinder stagger.the later c1 and c2ae blocks were a lot worse.
04-01-2021, 07:32 PM | #14 |
Re: 80 over rebuild
i always wonder about the thickness of walls bought a ultrasonic tester you will be done wondering about the block and learn alot
04-03-2021, 12:43 AM | #15 |
Re: 80 over rebuild
Sonic testing is the best way to proceed.
FYI, regarding racing applications, John or Geoff Mummert and Joe Crain, don't recommend boring a 312 block, more than .040. It's been said that the cylinder cores are the same on on the 292 & 312. I'm not a Y-block guy so, I have no experience with them, but, Geoff & Joe, have a lot of experience with them. There is one more that can be consulted, Ted Eaton: https://www.eatonbalancing.com/2000/...cing-articles/ Any of those 4 people, can tell you what is what, on a Y-block, it's how they make there living.
Frank '35 Ford Model 51 '48 Ford F3 '54 Ford Tudor Mainline |
04-03-2021, 07:48 AM | #16 | |
Re: 80 over rebuild
04-03-2021, 10:59 AM | #17 |
Re: 80 over rebuild
I think somebody has been drinking some of that corn.
04-03-2021, 11:13 AM | #18 |
Re: 80 over rebuild
Would you care to elaborate or even just reply in a somewhat knowledgeable manner?
04-04-2021, 02:39 AM | #19 | |
Re: 80 over rebuild
Let's look at this again. You somehow think my statement above about the Y-BLOCK 292/312 CASTING is not correct? If I am wrong, I am wrong. But bring facts, not potshots. Now, can you provide anything substantial to the contrary or will I be forced to post new SEX JOKES that seem to disturb you so badly ...
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... Last edited by KULTULZ; 04-04-2021 at 02:47 AM. |
04-05-2021, 04:45 PM | #20 |
Re: 80 over rebuild
I guess 'ol blacktie got held up yesterday in worship and bible class. Those terrible sex jokes he stumbled across here must have really worn him down.
Any who, for any other doubters - SOURCE - http://www.ford-y-block.com/Block%20identification.htm
