Old 04-19-2015, 11:09 PM   #1
daustin
Default My '55 Ford Mainline Project
Newbeee here. Here is my '55 Ford Mainline project. It has a 5.4L DOHC Lincoln Navigator motor, 4R70W Trans, aluminum drive shaft and Ford 9". All the body work is done and the drivetrain is in the car. It also has a front disk conversion and rack and pinion. I just got done wiring the MSD module to control the engine and will be moving onto the trans computer next. I just have to figure out what I did with the throttle position sensor...... Then it's off to a fabricator to figure out how to mount to the column to the rack as the engine is in the way... I look forward to updating this thread as my project moves along......
daustin is offline   Reply With Quote
Old 04-20-2015, 06:18 AM   #2
LOWRIDER
LOWRIDER's Avatar
Default Re: My '55 Ford Mainline Project
Welcome. That looks like it's going to be one nice ride. That ol' 55 should fly with that 5.4 set-up you have. Dan
Dan Kingman Az. 86409
LOWRIDER is offline   Reply With Quote
Old 04-20-2015, 09:54 AM   #3
scicala
scicala's Avatar
Love you're car and the fact that you are using carburetors.
Confused why you need a throttle position sensor though.
Sal
scicala is offline   Reply With Quote
Old 04-20-2015, 10:09 AM   #4
Gumpy
Gumpy's Avatar
Very nice car, love the dual carb setup
"I believe God is managing affairs and that He doesn't need any advice from me. With God in Charge, I believe everything will work out for the best in the end. So what is there to worry about". Quote by Henry Ford
Gumpy is offline   Reply With Quote
Old 04-20-2015, 10:58 AM   #5
daustin
Sal
Thanks! The TPS is for the transmission controller.
'55 Ford Mainline-Work in Progress
'14 Mustang GT, 6m, Recaros, Nav
'12 Ford Edge
Old 04-20-2015, 11:52 AM   #6
daustin
Thank you! I like the setup as well, but I will have to cut a hole in the hood. I'm not too keen on that, but it is what it is. It'll look good in the end though. The air cleaner will only stick out about 3". I'm also contemplating going to a shorter, single carb intake to avoid cutting the hood. I have a company local to me that makes them for this motor, but I will need to modify some things for it to work.
'12 Ford Edge
Old 04-20-2015, 08:26 PM   #7
69torino
Cool.
1956 Meteor Niagara Hardtop, 1 of 700
1969 Torino GT convertible 5.0 HO C4
1994 F150 XL short box
2006 Freestyle SEL
69torino is offline   Reply With Quote
Old 04-21-2015, 09:41 PM   #8
parklane
parklane's Avatar
Very nice start, and looks really good.
If brains were wire, some couldn't short circuit a firefly
parklane is offline   Reply With Quote
Old 10-04-2015, 07:59 PM   #9
Jersey Joe 67
Jersey Joe 67's Avatar
Dude you teased us, what's going on
Jersey Joe 67 is offline   Reply With Quote
Old 10-05-2015, 01:33 PM   #10
frank long island
frank long island's Avatar
as for your air cleaner maybe one that drops over the carbs sort of recessed like they used on the hemi's
frank long island is offline   Reply With Quote
Old 10-05-2015, 02:10 PM   #11
rowens55
rowens55's Avatar
That is one SWEET power plant!!!
Rowen
Alive n kickin n mostly kickin!
rowens55 is offline   Reply With Quote
Old 10-05-2015, 04:04 PM   #12
darrell
just wondering how he will fire the thing?
darrell is offline   Reply With Quote
Old 10-05-2015, 06:08 PM   #13
5851a
That's a awesome project, if you have to scoop it try a 55 Tbird style or the old super duty trucks.
5851a is offline   Reply With Quote
Old 10-05-2015, 08:42 PM   #14
Motorhead6
It'll probably work better on the street with one carb anyway. Didn't know that you could use that motor with carb and dist. Can you give us some details on setting that up and parts sources?
Motorhead6 is offline   Reply With Quote
Old 10-06-2015, 10:52 AM   #15
scicala
scicala's Avatar
I'm pretty sure there are cog belt driven distributors out there for racing that could be used to handle the spark.
Sal
Old 11-03-2015, 02:21 PM   #16
wagonmaster56
greetings to all, just joined the forum. Working on a 1956 ford wagon, and saw where you installed a 4r70w in your 55. I plan to install a 4r70w behind a rebuilt 312 I have in the wagon and I would like to know if you had to modify the trans tunnel, and what trans controller unit you used. I will be starting a thread on my build, looking forward to the group.
wagonmaster56 is offline   Reply With Quote
Old 11-05-2015, 09:23 AM   #17
RCM
RCM's Avatar
Damn, that is cool. Its gonna be a badass ride.
RCM is offline   Reply With Quote
Old 11-17-2015, 05:22 PM   #18
Ford Freak
Welcome aboard Wagonmaster ! My first car was a '56 Ford wagon that I bought for $175.00 back in 1972 @ age 16 . You can't buy a good grill for one today for that money ! Looking forward to your build thread .
Now , where is daustin , and the latest on the cool '55 Mainline ?
Ford Freak is offline   Reply With Quote
Old 11-24-2015, 08:16 AM   #19
fordsbyjay
For those asking about the ignition and distributor the MSD box he referred to in the OP uses the original cranks sensor to control the coils. There is no distributor, just the original 5.4 coils.
fordsbyjay is offline   Reply With Quote
