Old 07-30-2020, 08:22 PM   #16
40 Deluxe
Default Re: A few questions on a 8BA
Originally Posted by Los_Control View Post
I like that mod to the stand, would be a lot more stable. Well worth the time spent.
And I see you have your engine bolted by the exhaust bolts and not the rear .... I have heard of blocks cracking when hung from the rear ... guess was my question if the 8BA has same issue and should be hung from the side?
I was thinking the issue was limited to older Ford flatheads.
I do have a 49 dodge truck with a flat 6, I used the exhaust bolts on it, the 6 is long and skinny, it looks comfortable sideways on the stand.
The V8 just looks awkward sideways ... I guess this is not a fashion show.
Just taking a break from cleaning the mouse nest out ... it is not pretty, couple lifters are badly rusted from mouse pee.
I think today I will raise it back up on chain hoist, drain the dirty black oil from it.
Then set it back down, upside down. Pull the pan and get a good look at the bottom end.
So far, other then the mouse/lifter problem, is looking like a low mile virgin engine.
Sure am hoping can save it.
You might want to remove the pan before you turn the engine upside down. There is always some oil left after you drain it, and makes a mess when you roll the engine over.
