Old 07-11-2020, 01:55 PM   #19
V8COOPMAN
V8COOPMAN's Avatar
Default Re: 40’ Ford Brakes
Originally Posted by 1931 flamingo View Post
If I run a 5.90-15 on the front and an 8.20-15 on the rear, the rear has a lot more contac5t area. JMO
Paul in CT
Possibly, but probably not anywhere near as much as you might think (if much at all), especially if ALL tires are properly inflated. If properly inflated, the weight of the car is only going to displace or spread the tread out on the road surface to the degree that the weight of the vehicle is supported. Now, different rubber compounds, different radial/bias, etc. tire-construction types and tread configurations can make a difference in road adhesion qualities, but amazingly, tire contact patch area doesn't change that much with 'LARGER' tires. Simplistic example below! DD
Click Links Below __
T5 W/TORQUE TUBE
