06-09-2022, 09:58 PM | #1 |
misfire update
I got the '55 Ford 292 Y-block running today on all 8-cyls for the first time since I abandoned it in the garage last December.
Still, I am not satisfied with it. The engine idle speed seems to have slowed and sometimes, the engine surges between 500RPM and around 400RPM repeatedly. I increased the idle speed at the carb a little bit. I checked for a vacuum leak and sure enough, the rubber vacuum cap I had on my test port in the manifold vacuum tubing had cracked. I got out my vacuum tester and connected it to the manifold tubing. The vacuum was still very low, so I fiddled with the carburator idle/fuel mixture screws on the carb and got it up to 19 inches, but there is still that surge in idle. I disconnected the vacuum advance from the carb and plugged the tubing from the carb and connected my timing light and adjusted the timing to about 8 degrees BTDC then reconnected the vacuum advance tubing. BTW, here is everything that was replaced since January 2022. New points, condenser, rotor, distributor cap, spark plugs and spark plug cables. I swapped the cast epoxy ignition coil for a used oil filled coil that is more than 30 years old, but tested out okay. The carburator was taken apart, cleaned out with spray gumout, the inlet needle operation checked and a new power valve and gasket were installed and some new gaskets. A new fuel filter was installed. Anybody have any ideas about the idle surge??? |
06-09-2022, 11:54 PM | #2 | |
Re: misfire update
What engine/carb/trans setup do you have?
***** We should have a contest. The player has to start at the very last post of a thread & then try to guess what the OP's original question was about ... |
06-10-2022, 02:08 PM | #3 |
Re: misfire update
This is a 292 Y-block with all original '55 272 intake, carb and distributor (load-o-matic). It has Ford-o-matic trans. The carb is a Ford EBU (similar to the 51-53 Flathead carbs, but was used on all '54 Ford 239 Y-blocks). The fuel pump has vacuum booster. There is one tubing connection from fuel pump to intake manifold, off of which there is a compression "tee" and short piece of tubing with a vacuum cap (for use with vacuum testing guage). The vacuum cap was cracked, but now replaced. After I discovered the bad cap, I hooked the vacuum test guage to the tubing and was able to achieve a steady vacuum reading of 19. The only other vacuum line (coming off the third leg of the tee) is the line to the vacuum windshield wipers.
Typically, when timing an engine, I always pull the rubber hose (this is a new hose) off the tubing from the distributor vacuum advance and plug that hose with a pencil so that there is no signal from carburator to vacuum advance. I then proceed to run engine at idle and view the timing light at the pointer and adjust distributor as needed to get around 6-8 degrees BTDC. The only vacuum circuit I have not checked is the line to the windshield wipers. I will need to go buy some more vacuum caps to do that. |
06-11-2022, 02:35 AM | #4 | |
Re: misfire update
Here is a partial reading chart that may help. Just post what the needle is doing at idle and beginning of roll. - https://www.onallcylinders.com/2016/...auge-readings/
06-11-2022, 07:05 PM | #5 |
Re: misfire update
According to the guage reading chart, I shouldn't be unhappy about my vacuum reading (steady at 19 in, engine idling). No valve, ring or oil problems present. Timing seems to be right on the money too according to this.
I have just begun to wonder if a drop of gas every few seconds is falling off that new power valve down the throat and causing the on and off cycling surge of the idle. That would be a dissapointment as I worked like crazy to get a good gasket that fits right and used a brand new power valve. However, as I mentioned in the original post; I did test to see if the power valve or gasket leaked overnight prior4 to assembling the valve body to the main body. I did notice that the gasket (some type of red asbestos cement style gasket) was totally soaked with gas, but it hadn't dripped a drop overnight in the tuna can below unless that evaporated (I doubt it). But something like that might cause a surge like I am seeing here. |
06-11-2022, 08:14 PM | #6 |
Re: misfire update
06-12-2022, 07:46 AM | #7 | |
Re: misfire update
What does the gauge do when she begins to roll?
06-12-2022, 08:57 PM | #8 | |
Re: misfire update
I have noticed that the modern PV's have a radius chamfer at the gasket surface, but they should be perfectly flat, but if you can get a good gasket, they might work, but always need to be tested for leaks first. I also asked Charlie if he had any ignition condensers for '54/55/56 Y-blocks. Told him I wanted to buy four of each (PV's and condensers). That should last me till I'm six feet under. |
06-12-2022, 09:14 PM | #9 | |
Re: misfire update
Right now, I have a spare carb sitting on a tuna can with gas in the float bowl to sit overnight and see if the power valve leaked into the tuna can in the morning. There is no whistling noise anywhere, but when the idle surges down, sometimes you can hear a sound like compressed air rushing out at high pressure from cylinder #8 somewhere. I pulled the spark plug boot and tried to tighten #8 spark plug but it is already super tight. But when the idle is up, there is no air rushing sound. It is a minimal spurt, like it may be coming out of #8 intake valve guide, but thats a wild guess. All cylinders are firing great and engine starts up like brand new. |
06-14-2022, 01:21 AM | #10 | |
Re: misfire update
Sorry ...
06-20-2022, 01:37 AM | #11 |
Re: misfire update
After swapping the carburator with my spare rebuilt one, there is no more idle surging at all and the engine runs and drives like new. Checked vacuum after carb swap and it is still reading steady at 19. Didn't even need to turn idle/fuel mixture screws. The new rubber vacuum cap should hold up till after I'm dead based upon how long the other one lasted.
She's back on the road again. |
06-20-2022, 08:23 AM | #12 |
Re: misfire update
Glad you found the cause Dave ...
06-21-2022, 05:00 PM | #13 |
Re: misfire update
Apparently, my suspicion about the leaky power valve was correct, even though I had done an overnight check to see if it was leaking gas, but there wasn't a drop in the tuna can. However, when I looked at the bottom of the main body of the carb, the red gasket for the power valve was soaked.
Now that I have been driving the car with the spare rebuilt carb on it, I have noticed that all it takes for the float bowl to leak dry is to let it sit for over 24 hours. Just enough gas left in the float to start the engine, then it immediately dries. I am back to getting out, taking the oil-bath air-cleaner off, dumping a half a tuna can of gas down the air-bleed tubing in the carb throat (which fills the float bowl). Get back in and it fires right up and ready to go down the road. At this point, I don't drive everyday, so it is likely I will always be taking the air-cleaner off and dumping gas in the carb just to get going. BTW, I tried to get hold of Charley NY about getting some power valves and mating gaskets weeks ago, but he apparently doesn't visit this site very often. Anyway, here is my theory of the idle surge that was happening; there may be a small drip between PV and gasket which would rev the idle up a little bit till that drip is burned, then the idle settles back down. The drips occur at around 3 second intervals so it seems like the idle is surging every 3 seconds. I have also checked the accelerator pump ball check, but it is properly seated by the spring-clip (both carbs). This carb that is on the manifold now is primo! The carb I just took off of it was rebuilt, but I noticed some damage to valve-body to main body gasket and the power valve gasket not fitting well (perhaps not even the right power valve for the mating surface of this carb. I fixed all that (I think) and placed it back in the spare box. I will wait until it is time to swap again before I test for leaks on the bench. Nevertheless, there is no more idle surge and the engine sails down the road at any speed or acceleration I want. Thanx to everyone for your input |
