12-24-2010, 03:57 PM | #1 |
Coil Question
My father inlaw has a depot hack style T with what may be a 1915 +- motor. The motor has been changed from the coil box to a distributor. The spark seems to be weak and a yellow color and the motor will not start. It will fire a couple of times and thats all. He feels that he has it in time.
He was told that a T without a coil box needs a hotter coil. Any ideas on where to start to get better fire and on the road? Thanks........................ |
12-24-2010, 05:37 PM | #2 |
Re: Coil Question
If you are using a modern style distributor use a modern style coil that matches the battery voltage
12-24-2010, 05:55 PM | #3 |
Re: Coil Question
Dirty points or a weak condenser can cause this type of trouble as well.
12-25-2010, 06:38 PM | #4 |
Re: Coil Question
