Old 12-31-2010, 10:46 AM   #1
Jalopy Tin
Default I have to turn my nuts..
Where can i find a good torque chart/info about the most torque on a model T? Is there any summary somewhere?
Happy New Year all of You !!
/Tom
Jalopy Tin is offline   Reply With Quote
Old 12-31-2010, 11:10 AM   #2
Jalopy Tin
Default Re: I have to turn my nuts..
Ok, ford did not use torque wrench back then, but different length of wrenches and turned them until the hair on the arm stood up...?
I found a good chart for torque in common.
http://www.mtfca.com/discus/messages...hart-28380.doc
/Tom
Old 12-31-2010, 02:27 PM   #3
tmodelman
tmodelman's Avatar
Sage advise. For old bolts and nuts on the Model T, don't use any wrench longer than factory tools. I always stay with 3/8" socket set, the handle is about 8" long, can't get into too much trouble unless you are Gov. Arnold.
As for torque on head bolts....be careful on early blocks, later blocks can take up to 50 ft/lbs. Torque to that after hot too, to seat the head bolts. You'll find they back off to about 45 after running a bit when new gasket is used.
tmodelman is offline   Reply With Quote
Old 12-31-2010, 07:06 PM   #4
Jalopy Tin
I have now understand that i have to be careful, not to use too much torque. Thanks tmodelman.
I'm not a purist, so i will use model A headbolts and nuts. I believe i have a -25 engine..
My title says -23, but engine number says -10 (203xxx)
High head, 4 dip pan, no ford text on block, all three bands are the same width, one piece valve cover, large hogs head cover etc.
What does this mean? June 1925?
/Tom
Old 12-31-2010, 07:31 PM   #5
John Otis
John Otis's Avatar
Send a message via AIM to John Otis Send a message via Yahoo to John Otis
When you have taken apart and put together as many T engines as I have you develop a feel for tight that never goes away. Those of us who have been there know when tight is tight and just where the "too tight" line is. I wouldn't venture a guess what the torque wrench would say but rest assured things may be made properly tight with no measuring besides the feel of the situation.
John Otis is offline   Reply With Quote
Old 12-31-2010, 08:30 PM   #6
CharlieB
CharlieB's Avatar
Modeltman is right about wrench sizes and John has it correct about the "tight feel". I guess it explains the reason for all those cotter pinned bolts all over the car and engine. The only torque spec I've ever seen is for the head bolts.
CharlieB is offline   Reply With Quote
Old 01-01-2011, 11:38 AM   #7
Willie in Houston
Willie in Houston's Avatar
Tom, I think Langs and other parts venders have torque specifications in their catalogs. You might try looking up one of the venders on line, they have most of their catalogs shown in their Websites and may also show torque specifications.?????
Willie in Houston is offline   Reply With Quote
