Old 08-30-2021, 10:15 AM   #1
AnthonyG
AnthonyG's Avatar
Default Yellow Teflon tape on oil filter connections?
Anybody have oil seepage issues with the oil filter connections & has anyone had success with yellow Teflon tape?
Nomad
AnthonyG is offline   Reply With Quote
Old 08-30-2021, 10:42 AM   #2
Bored&Stroked
Bored&Stroked's Avatar
Default Re: Yellow Teflon tape on oil filter connections?
It all depends on the type of fittings you're using --> two basic types compression (and there are a few types of those), versus a pipe thread type fitting.
Teflon tape works fine for a tapered pipe thread type fitting, but is not of much use on a compression fitting (where they seal by two machined surfaces coming together, or via a ferrule or flare that interacts with two machined surfaces.
If you're leaking at a compression fitting, then it is usually an issue with the mating surfaces not doing their job, ferrules not working, etc..
Old 08-30-2021, 12:34 PM   #3
woodiewagon46
The only place I use Teflon Tape, white for water or air and yellow for natural gas is for where it was designed to be used, on plumbing jobs. What I use on automotive threads is Locktite 569, Thread Sealant. If it's a hydraulic fitting I use Locktite 545, Pneumatic/Hydraulic Seal. Leave the Teflon tape for plumbers.
woodiewagon46 is offline   Reply With Quote
Old 08-30-2021, 01:08 PM   #4
Los_Control
My humble opinion. As a retired remodel carpenter, I have done many kitchens & bathrooms.
I would use teflon tape on items you see, such as a faucet or a shower head. & yellow is for gas.
I always had a better seal with pipe dope. The just right amount of pipe dope will ooze out as you tighten the joint.
You can see where it would be a pain to use pipe dope on a shower head, then spend a 1/2 hour cleaning it ... when teflon tape is acceptable and just move on. Thats important when doing the finish work on plumbing.
Whatever you do, make sure you start the product far enough back on the threads so it does not get inside the oil lines.
My choice would not be teflon tape on oil lines, I would spend the time to clean them afterwords ... either will work though.
Los_Control is offline   Reply With Quote
Old 09-01-2021, 06:24 AM   #5
AnthonyG
AnthonyG's Avatar
Thx, guess I go in another direction. The fittings were supplied mounted on the formed steel connection lines & the one connecting to the feed port on canister leaks. Thought initially it was the canister leaking but did a pressure check & it’s OK. Tried the Teflon yellow & it continued to leak. Thinking the flare may be bad. I’ll try to reshape with the flaring tool. I hate to cut it & re-flare as there’s not a lot line left to reshape.
I did some research & found out some interesting things on Teflon tape. The only real difference between the white & yellow is the color which identifies the thickness. Yellow is thicker & I didn’t know there is a red too which is a lot thicker. Both yellow & red are use for larger diameter pipes. & fittings. Heat wise both good for 500 degrees.
Thx for the help.
Nomad
Old 09-01-2021, 12:31 PM   #6
JSeery
JSeery's Avatar
I have to agree, don't think Teflon tape is going too help any on a flared fitting.
Old 09-01-2021, 02:20 PM   #7
AnthonyG
AnthonyG's Avatar
I’ll try to reshape the existing flare before cutting & starting fresh. Hopefully the process of tweaking the line during install is what damage the flare & reshaping with flare tool will work.
Nomad
Old 09-01-2021, 10:32 PM   #8
fordor41
fordor41's Avatar
try tightening and loosening a few times to get the flare to seat. Works on brake lines
fordor41 is offline   Reply With Quote
Old 09-02-2021, 05:00 AM   #9
Bored&Stroked
Just make sure there are no cracks in the tubing/flare itself . . . sometimes you just need to make a new line. If you decide to make new lines, look at NiCop type tubing - is easy to form and available from places like Jegs, Summit, etc..
Old 09-02-2021, 04:08 PM   #10
don35
Nicop is also sold at our local Carquest, and NAPA stores. With the it's corrosion resistance to road salt, and easy workability, that's almost all they sell anymore.
don35 is offline   Reply With Quote
Old 09-02-2021, 04:15 PM   #11
AnthonyG
AnthonyG's Avatar
👍thx
Nomad
