Old 04-27-2016, 07:29 PM   #1
Fourdy
Fourdy's Avatar
Default Skip's pumps
I just read Skip's face page and noted for the first time that he states:
"super turbine impeller on 37 - 48 type pumps"
"new improved high volume impeller on 32 - 36"
49 - later not mentioned. Does that mean my late waterpumps did not get the benefit of "improved flow"?
Fourdy
Fourdy is offline   Reply With Quote
Old 04-27-2016, 08:17 PM   #2
Lenny51
Lenny51's Avatar
Default Re: Skip's pumps
I had my 51 pumps rebuilt by Skips the impeller was different than my
originals the new design pumps more coolant per hour or minute
Lenny51 is offline   Reply With Quote
Old 04-27-2016, 09:58 PM   #3
Ol' Ron
Ol' Ron's Avatar
I wonder if you can get the truck pumps with narrow belt pulleys.??
Ol' Ron is online now   Reply With Quote
Old 04-27-2016, 10:08 PM   #4
Fourdy
Fourdy's Avatar
Lenny, just curious how you were able to verify more flo? I would like to check mine.
Fourdy
Old 04-27-2016, 10:08 PM   #5
tubman
tubman's Avatar
I have spoken to Skip about this exact subject. He says it is no problem, but the figure he quoted me was eye opening. I have a lot of late model pumps of both kinds, but no press. I am thinking of buying a shop press. If you think about it, it shouldn't be a difficult task.
Old 04-27-2016, 10:21 PM   #6
flatjack9
flatjack9's Avatar
That's what I did.
Old 04-27-2016, 10:30 PM   #7
Ross F-1
Ross F-1's Avatar
The only problem is getting the sheaves on/off without bending or breaking them. I had to convert Truck pumps to narrow sheaves for the EAB that came in my truck.
'52 F-1, EAB flathead
Ross F-1 is offline   Reply With Quote
Old 04-28-2016, 07:42 AM   #8
G.M.
Skip can put whatever pulleys you want on. It would be best if
you can supply the pulleys, new pulleys are about $30.00 each.
The guys that did their own still have the stock impellers and
don't get the better cooling benefit of almost tice the coolant
circulating through the system. It's not just a simple rebuild
job to install the turbine impellers. The body of the pumps are
machined in the lathe to make a 22% seat for the turbine
impeller. When the pump is assembled a close tolerance
clearance is maintained between the impeller and the new
seat. This is how more flow is produced compared to the old
paddle wheel type impeller just sitting in water spinning it's
wheel and pumping air.. He also installs a hard SS shaft and
modern seals. Plus you can not get a better guarantee
anywhere. G.M.
www.fordcollector.com
Old 04-28-2016, 07:56 AM   #9
Tim Ayers
I think there are some things it pays to DIY and some things it pays to pay someone to do it. This is one of the jobs it pays to have it done right.
Taking out a leaky pump once everything is install is not a hard job, but its a job you want to avoid the first time around.
Just my two cents.
Old 04-28-2016, 11:31 AM   #10
V8COOPMAN
V8COOPMAN's Avatar
Originally Posted by G.M. View Post
.....the better cooling benefit of almost tice the coolant circulating through the system.
Your statement, if taken literally, implies that the number of quarts of water has ALMOST DOUBLED in the system. I'm guessing that your statement would be more accurate if it read something like....."benefit of almost twice the rate of flow of the coolant circulating through the system", though I could be full of it! DD
Click Links Below __
T5 W/TORQUE TUBE
Old 04-28-2016, 12:13 PM   #11
Fourdy
Fourdy's Avatar
With all due respect, i haven't gotten an answer to my question as to whether the late model pumps have the special turbine since the ad does not state so. Does anyone know?
Thanks,
Fourdy
Old 04-28-2016, 12:39 PM   #12
scooder
Fourdy,
It's best to ask the man himself I'd have thunk.
For your information, the later 8BA style pumps already have a proper impeller style doings. Not like the earlier flat paddle type. And do pump water at an already crazy amount. No need to gild that Lilly in my opinion.
But like I said, see what skip says.
Martin.
scooder is offline   Reply With Quote
Old 04-28-2016, 12:57 PM   #13
krackerjack1951
krackerjack1951's Avatar
if the pumps send water thru the radiator too fast there is a loss of heat exchange..think about that..thermostats impede the water flow to allow water to cool while in the radiator...not really rocket science....water screaming thru the poorly design flattie @ 70 mph is a no no.statts wide open,,no heat exchange,,engine will bump 212 july hot...I'm done with that..
krackerjack1951 is offline   Reply With Quote
Old 04-28-2016, 01:38 PM   #14
V8COOPMAN
V8COOPMAN's Avatar
Boy, you better stand-by and brace yurself for an edumacation from the "x-perts" on thermodynamics........while I get some popcorn cooked-up! DD
T5 W/TORQUE TUBE
Old 04-28-2016, 01:45 PM   #15
flatjack9
flatjack9's Avatar
Been through it so many times, I'll pass. However he is so wrong.
Old 04-28-2016, 03:35 PM   #16
texas webb
You can e-mail Skip and he will answer.
texas webb is offline   Reply With Quote
Old 04-28-2016, 03:37 PM   #17
Kube
Kube's Avatar
Oh man, you nailed it! Just wait until GM sees that post! This is gonna get fun! I am going to pop a large bowl of popcorn and like you, sit back and enjoy.
I used to rebuild my pumps - it's easy. A number of years ago, I found it more cost effective to have Skip (George) do them for me. I gotta say, I have had Skip build numerous pumps for me to date. Each and every one has performed flawlessly. Great guy and great workmanship. No question about that.
Now, did any of his pumps make a bit of difference of operating temperature on any engine I'd installed them upon? Nope, not a one.
Keep in mind, every engine I rebuild, I rebuild properly. I also rebuild each radiator properly and no doubt restrict the flow somewhat by installing 155f thermostats in all engines.
Nope, never found the need for "super magical high volume impellers" nor "Water Wetter", nor "Purple Ice". Never found the need for an overflow tank and / or pressure valve. Not even a 4# cap...
Oops, popcorn is done. Gotta go.
Old 04-28-2016, 03:40 PM   #18
petehoovie
petehoovie's Avatar
Who?...."is so wrong"?....
Old 04-28-2016, 03:55 PM   #19
kurtis v-8-60
kracerjack 1951, is right on. slow it down and cool it down. I run v8-60 in race car ran 240 all the time until I learned how to slow the flow of water down. on hot days never runs over 190 think about what kracerjack said
kurtis v-8-60 is offline   Reply With Quote
Old 04-28-2016, 04:17 PM   #20
sidevalve8ba
sidevalve8ba's Avatar
Kube, pass the popcorn, please?
The more I learn about new automobiles, the more I value my old ones.
sidevalve8ba is offline   Reply With Quote
