Old 09-19-2019, 09:40 AM   #1
Gino
Default Broken gless
Hi, had a friend slam the door. Glass shattered. I’m just looking for the best way to repair. Thanks
Gino is offline   Reply With Quote
Old 09-19-2019, 09:41 AM   #2
AlexLohmann1
AlexLohmann1's Avatar
Default Re: Broken gless
Replace with new
AlexLohmann1 is offline   Reply With Quote
Old 09-19-2019, 09:51 AM   #3
Chuck Dempsey
Chuck Dempsey's Avatar
And pay extra for 'safety glass'....
Chuck Dempsey is offline   Reply With Quote
Old 09-19-2019, 09:52 AM   #4
AlexLohmann1
https://www.mikes-afordable.com/category/1132.html
Is just one source of said safety glass.
You can also try local glass shops as well.
Sent from my SM-G975U using Tapatalk
Old 09-19-2019, 10:34 AM   #5
Purdy Swoft
Purdy Swoft's Avatar
You didn't mention the body style . On most if not all have a plate on the inside top of the door frame that attaches with three slot head screws . The glass is installed or replaced through the top of the door . Sometimes it may be necessary to remove the regulator to get the roller in the track on the bottom of the window .
Old 09-19-2019, 10:46 AM   #6
nick c
Default Re: Broken glass
I broke a fairly new window glass on my 29 cc, it was safety glass, the door had a problem not staying closed, the glass was not all the way down, I grabbed the glass and slammed it closed, it broke, there are screws that hold the felt channel in, make sure the screws are not binding up with the glass. I fixed the door latch.
carry on
nick c is offline   Reply With Quote
Old 09-19-2019, 11:24 AM   #7
Purdy Swoft
Usually adjusting the striker plate too tight in an attempt to adjust a loose rattling door will cause the door to not stay fully closed .
Old 09-19-2019, 11:30 AM   #8
Tacoma Bob
Tacoma Bob's Avatar
Through the years I have owned several Model "A"s. After the third friend broke yet another door glass I learned to open the door and close the door for them. For whatever reason people think they need to slam the bejesus out of either an old car door or a truck door. That is the primary reason I stopped loaning out my pick up truck. I tell folks to rent one.
Tacoma Bob is offline   Reply With Quote
Old 09-19-2019, 12:32 PM   #9
Purdy Swoft
I don't like for my doors to be slammed . It is best to never slam the door with the window part way up or down or it can result in a broken window . I have broken two oir three windows over the years myself .
Old 09-19-2019, 12:41 PM   #10
burner31
burner31's Avatar
I went to my local auto glass shop, they took care of me and it did not cost an arm and a leg, and I didn't have to wait or pay for shipping.
Keith
Shawnee OK
'31 SW 160-B
burner31 is offline   Reply With Quote
Old 09-19-2019, 06:43 PM   #11
Gino
Thanks, I want to go to a local auto glass shop and not order from supplier if possible. Thanks ahain
Old 09-19-2019, 07:15 PM   #12
dbaldwi3
dbaldwi3's Avatar
Just purchased a passenger side glass for my Tudor locally for $47.00 installation was pretty easy. As a side note today I installed all the new door hardware and concluded it’s best to turn handle close/open door then release handle instead of slamming the door
dbaldwi3 is offline   Reply With Quote
