08-30-2019, 04:12 AM | #1 |
Zero Grease Fitting Replacement
I bought a set of replacement Zerk grease fittings from Bratton’s. Some of the old fittings look pressed in. What is the easiest way to remove them without breaking the old fittings?
Sent from my iPhone using Tapatalk |
08-30-2019, 05:26 AM | #2 |
Re: Zero Grease Fitting Replacement
A small chisel and hammer...work your way around the zerk...it will soon come out.
Pluck |
08-30-2019, 08:03 AM | #3 |
Visegrip pliers.
Bob Bidonde |
08-30-2019, 09:35 AM | #4 |
Vicegrips...clamp, twist and pull. (My dentist does it best)
Alan 1929 Special Coupe 1941 Pick-Up 1955 Victoria |
08-31-2019, 04:00 PM | #5 |
As others have said, like removing a tooth - vice grips and rock it back and forth while pulling.
08-31-2019, 04:37 PM | #6 |
I hab done it about 10 years ago and I do not remember it being that hard. You will need the special tool to drive them in. The holes are too big to tap 1/8 pipe for screw ins. John
Welcome each day |
08-31-2019, 08:05 PM | #7 |
Well, I have do ask, do they require anesthetic?
