Old 08-24-2019, 07:36 PM   #1
chrs1961815
chrs1961815's Avatar
Default Transmission Issues
While driving the roadster a fair amount today back and forth, I noticed the transmission is acting differently in a bad way. It grinds gears if you're going from neutral to low or reverse no matter what. I just adjusted the clutch adjusting arm and there is acceptable play, so I am scratching my head. Bad news?
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-24-2019, 07:40 PM   #2
ryanheacox
ryanheacox's Avatar
Default Re: Transmission Issues
Is your clutch arm original? They like to crack and it won’t show up unless you depress the clutch.
ryanheacox is offline   Reply With Quote
Old 08-24-2019, 07:46 PM   #3
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
I bet Ryan is right.
Jacksonlll is offline   Reply With Quote
Old 08-24-2019, 07:54 PM   #4
Y-Blockhead
Y-Blockhead's Avatar
That they do. Usually you will have an increase in free play tho.
Picture of mine.
Old 08-24-2019, 08:26 PM   #5
chrs1961815
Just checked, no crack when depressed or at all. Might be original, might be a reproduction.
Old 08-24-2019, 08:41 PM   #6
ryanheacox
ryanheacox's Avatar
Try closing up the free play and see if it gets better?
Old 08-24-2019, 08:43 PM   #7
Joe K
Joe K's Avatar
Not reproduced as original. Repops are made of welded steel.
Check for relative motion between the shaft and arm, not necessarily a crack.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 08-25-2019, 04:44 AM   #8
Wick
Wick's Avatar
From neutral sitting still at a idle,can you go to 2nd easily then back down to 1rst without and problems?
Also is your idle speed correct ? Has transmission fluid been checked?
I would also inspect the shift rail,forks,shifter ball.*
Wick is offline   Reply With Quote
Old 08-25-2019, 07:44 AM   #9
Bob Bidonde
Bob Bidonde's Avatar
Grinding gears will happen when the transmission oil level is too low.
Bob Bidonde
Old 08-25-2019, 09:35 AM   #10
Railcarmover
engine running car stopped grinding going into low or reverse?you have a clutch problem.If this is the case,the clutch does adequately release the input shaft from engine power....
Railcarmover is offline   Reply With Quote
Old 08-25-2019, 09:39 AM   #11
chrs1961815
Joe K
Definetely an original. I can slide the arm and shaft in and out of the trans, don't know if that means the bushing is shot.
At neutral, I can't slide into any gear. If the car is stopped, it still is a problem.
Old 08-25-2019, 09:47 AM   #12
rotorwrench
rotorwrench's Avatar
There may be an issue with the clutch cover or disc. It has to completely disengage for the cluster gear counter shaft to slow to a stop.
Old 08-25-2019, 10:02 AM   #13
1931 flamingo
1931 flamingo's Avatar
Did it grind BEFORE you made the adjustment?? Paul in CT
Old 08-25-2019, 10:02 AM   #14
1931 flamingo
Paul in CT
Old 08-25-2019, 10:09 AM   #15
Gold Digger
Not on a Model A but on a truck I once had, the pilot bearing was bad and caused a drag on the pilot shaft of the transmission. This truck had a ball bearing pilot bearing. Just a thought.
Gold Digger is offline   Reply With Quote
Old 08-25-2019, 10:09 AM   #16
Joe K
Joe K's Avatar
May be an issue with the "fork." This is held to the shaft by a pin. The pin may have sheared or worked loose.
Joe K
Old 08-25-2019, 11:07 AM   #17
chrs1961815
I drained the oil which I only replaced a few months ago and was as already looking dirty and I am cleaning with kerosene. I pulled the floorboards and noticed that the gear shift lever has a pin on mine that goes through the shifter tower and it was halfway out. Can't find the part on Brattons and I don't think it is a shifter fork. I lined it back up and drove it in.
Old 08-25-2019, 11:07 AM   #18
chrs1961815
It did seem to get worse after I adjusted it last week. I DID replace the clutch adjusting arm with a repro because mine was getting too worn.
Old 08-25-2019, 12:26 PM   #19
Patrick L.
Patrick L.'s Avatar
A couple things come to mind.
How much freeplay does it have ? Acceptable doesn't mean too much to me. It should be 1.0-1.5".
If the floorboards are removed along with the clutch inspection plate, the clutch operation can be watched.
The trans should be able to be shifted with engine off. The cover may need to come off and the shift lever ball along with the shift forks may need to be looked at. The lever ball should be close to being round [ 1/2"] as they tend to become square over the decades.
Old 08-25-2019, 01:41 PM   #20
chrs1961815
I pulled the whole tower and everything looks OK. My shifter ball is still a ball and everything seems to be in good shape.
