Old 07-03-2015, 03:21 PM   #161
LSJUNIPER
Default Re: Flathead project
It's been awhile since I have posted any progress on the flathead project...
That being said I finally was able to put the new flywheel, clutch and
pressure plate on today....!!
LSJUNIPER is offline   Reply With Quote
Old 07-04-2015, 08:05 AM   #162
cavecreekjake
And use the pilot bearing, not a bushing.. My bushing squeals like hell from time to time. I'll change it when I get around to pulling the engine !
cavecreekjake is offline   Reply With Quote
Old 07-04-2015, 01:14 PM   #163
LSJUNIPER
Yes, I did put a pilot bearing in the flywheel..if that's what you mean......
Old 07-04-2015, 02:58 PM   #164
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Come up here to Me. Phil and we'll go to coast and get some clams. If there to cold we'll steam em. Walt
Walt Dupont--Me. is offline   Reply With Quote
Old 01-11-2017, 11:39 AM   #165
LSJUNIPER
Its been awhile since I posted on here, thought I would post an update. Attached are some pics of what the motor will be going in.
Old 01-11-2017, 01:00 PM   #166
revkev6
perfect!
if you don't mind my asking what did they charge you to hot tank your motor and pull the studs??
did you ever fire it??
revkev6 is offline   Reply With Quote
Old 01-11-2017, 08:24 PM   #167
LSJUNIPER
The hot tank, power wash, wire brush, was 75 bucks. the stud work was 120 bucks.
Have not started it yet. Was thinking of finishing the rolling chassis, installing the motor then start it up.
Old 01-12-2017, 08:48 AM   #168
revkev6
thanks... I'm in the springfield area and i'm always looking for decent machine work. same guy do the rest of your machine work?? did your crank need grinding too??
Old 01-12-2017, 11:39 AM   #169
LSJUNIPER
Eastwoods Auto Machine did all of the machine work, they did grind and balance the crank. If I ever need work done that's the place I will go to.
Old 03-06-2018, 05:54 AM   #170
LSJUNIPER
Finally dropping the motor into the frame.
Old 03-06-2018, 07:34 AM   #171
JSeery
JSeery's Avatar
Man, that is looking good! What clutch and pressure plate did you end up going with?
Old 03-06-2018, 10:48 AM   #172
cas3
looks nice, but seems like the motor is quite a ways back from the front crossmember. i trust you have had a body on?
Old 03-07-2018, 11:55 AM   #173
LSJUNIPER
Purchased the clutch and pressure plate from Speedway.
Old 03-07-2018, 11:56 AM   #174
LSJUNIPER
Have not placed the body onto the frame yet. Will do that once I have a full rolling chassis.
Old 03-07-2018, 04:33 PM   #175
pooch
pooch's Avatar
wow, my AV8 needed the front mounts only just behind the crossmember and the crankshaft nut was over the crossmember, in between the U bolts and is was still a very tight squeeze to firewall and this was a 28 , not a 31.
That chassis to me seems a lot longer than standard in the pics.
Is it still 103 1/2 inch wheelbase?
pooch is offline   Reply With Quote
Old 03-07-2018, 07:38 PM   #176
B-O-B
B-O-B's Avatar
Might be mid-engine ford coupe???
B-O-B is offline   Reply With Quote
Old 03-08-2018, 12:37 PM   #177
GreenMonster48
GreenMonster48's Avatar
How about a pic of the F100 you've got parked next to it?
GreenMonster48 is offline   Reply With Quote
Old 03-08-2018, 11:35 PM   #178
Notadufus
Being nosey, here...Did you pull the plugs out of the crank, to clean out the sludge, then replace with new plugs? (Few modern machinists know to do that, these days) I recently built a '49 239 and the crank was completely stopped up with asphalt-like crud. I got new plugs from VanPelt. With good oil and semi-full flow filter, the engine should out-last me!
You're doing beautiful work and that sucker should run like the wind! Can't wait to see the end results!
Notadufus is offline   Reply With Quote
Old 03-09-2018, 05:58 AM   #179
LSJUNIPER
I will take some measurements tonight.
Old 03-09-2018, 06:02 AM   #180
LSJUNIPER
Here is the truck.
