Old 09-22-2024, 10:12 AM   #161
slowforty
Default Re: What did you do today that was flathead V8 related?
Just charged the battery on the 40. And Remembered to disconnect the battery so is does not go dead. (Again)
slowforty is offline   Reply With Quote
Old 09-23-2024, 10:06 AM   #162
Sixseven
Sixseven's Avatar
I've not done a thing to the car but run gas through the carburetor. I've put almost 200 miles on the car in the last month and a half.
Things need to be done, but I don't like the prospect that the car would or could be laid up for any length of time. I do have a fully rebuilt OD trans from Van Pelt to install. That's one of the things that needs to be done, along with resealing the engine, rebuild the carb and front end. For now, it's the sound of the flathead working through the streets around my house.
1940 Buick Roadmaster Convertible Coupe
1939 flathead engine, fully rebuilt
1967 Ford Mustang Convertible
1950 Mercury Woodie
Sixseven is offline   Reply With Quote
Old 09-23-2024, 02:17 PM   #163
Tim Brown
Tim Brown's Avatar
Originally Posted by ndnchf View Post
I just finished restoring this generator. At first glance it looks like a stock 6 volt generator. But in fact it is a full 12 volt, negative ground conversion using a 12 volt armature and new 12 volt field coils. It will be going to Hershey in a couple weeks along with other restored generators and refurbished original cutouts.
You do nice work. Im watching and learning...
Tim
Tim Brown is offline   Reply With Quote
Old 09-25-2024, 05:36 PM   #164
ndnchf
ndnchf's Avatar
Thanks Tim :-)
I finished up this one today, kind of a 6 volt hybrid. Its a mix of parts that has a fan mount pulley, using the extra large 1937-1938 style bearing fork mount to carry the fan load, mated to a 1941and later 2-brush body. It is similar to the '39 standard/pickup generator. It was running on the test bench today, pushing over 30 amps. This will be on my table at Hershey, along with other restired generators.
ndnchf is offline   Reply With Quote
Old 09-25-2024, 08:26 PM   #165
Zeke3
Zeke3's Avatar
That is a great looking generator and it sounds like a real workhorse at 30 amps output.
Zeke3 is online now   Reply With Quote
Old 09-26-2024, 05:57 PM   #166
fordv8j
fordv8j's Avatar
Cleaned our 38 deluxe coupe we have owned for 60 years
fordv8j is offline   Reply With Quote
Old 09-27-2024, 10:57 AM   #167
Ol' Ron
Ol' Ron's Avatar
I don't use a generator, just an alternator, no stock fuel pump? intank electric and no mechanical fam, also electric 8BA water pump, yes the work quite well on the 59 blocks just plug the hole make the adapter for the early motor mount, another trick is to use the passenger side water pump pulley on the driver side and run one narrow belt and a chevy harmonic pulley. All this makes the engine more reliable and quitter
Old 09-28-2024, 04:54 PM   #168
fordv8j
fordv8j's Avatar
Took 38 dlx coupe to a show..got best ford. About 150 registered
Old 09-28-2024, 05:02 PM   #169
ndnchf
ndnchf's Avatar
Wink Re: What did you do today that was flathead V8 related?
I took the '35 to local show at the YMCA.
Old 09-29-2024, 11:18 AM   #170
Cecil/WV
Cecil/WV's Avatar
Working on a Mercury overdrive, getting it ready to assemble and sell!
Cecil/WV is offline   Reply With Quote
Old 09-29-2024, 02:37 PM   #171
Model51
Model51's Avatar
Yesterday mounted the painted cab on the frame. Finally some visual progress. Today I'm tackling the torque tube and drive shaft installation.
1935 157" 1 1/2 ton stake truck undergoing full original restoration
1936 131 1/2" panel truck rescue preservation
Author of the 1935-1936 Ford Model 51 V8 Truck book published by the Early Ford V8 Club of America
Model51 is offline   Reply With Quote
Old 09-29-2024, 03:06 PM   #172
glennpm
glennpm's Avatar
I adjusted my shocks yesterday. I had a record of my settings but was also surprised to find loose shock arms to shock shaft. Took it out this morning on mostly rough roads, and the ride was Much better!
Glenn
Old 09-29-2024, 03:59 PM   #173
1948F-1Pickup
1948F-1Pickup's Avatar
“Enjoying” figuring out the correct order of putting all this stuff back together after popping a head gasket awhile ago.
1948F-1Pickup is offline   Reply With Quote
Old 09-29-2024, 04:51 PM   #174
rich b
rich b's Avatar
Looked at an engine my kid picked up and wondered why the "59" engine was relieved.
rich b is offline   Reply With Quote
Old 10-01-2024, 03:13 PM   #175
ndnchf
ndnchf's Avatar
Just finished winding and wrapping a new set of 12 volt 1941-1964 generator field coils.
Old 10-01-2024, 03:38 PM   #176
Zeke3
Zeke3's Avatar
I have been working on cleaning the rust and grease off the rear axle and driveshaft for my 1937. What a cloud of rust dust, thank goodness for a good face mask. I had the rear radius rods sand blasted and I welded up the holes that were from the hydraulic brake lines and emergency brake cables installation, then painted them. Also, disassembling a pair of 1937 brakes so that I can clean up and paint the backing plates.
Old 10-03-2024, 11:30 AM   #177
slowforty
Cleaned and checked the 40 for a 200mile trip to the New Port Indiana Hill Climb
and put it up for sale.
Old 10-03-2024, 05:33 PM   #178
cadillac512
cadillac512's Avatar
Drove mine to work again. Every day this week.....beautiful weather for a change!
"It don't take but country smarts to solve the problem" (Smokey Yunick)
'30 Model A Speedster
'41 Merc Town Sedan / 260" 8CM engine
'66 Fairlane four door / "warmed up" 302
cadillac512 is offline   Reply With Quote
Old 10-04-2024, 08:00 AM   #179
Zax40
Zax40's Avatar
Did you list it here? I don't see it.
Zax40 is offline   Reply With Quote
Old 10-04-2024, 01:13 PM   #180
Model51
Model51's Avatar
Installed dynamat inside the cab. Also attached the windshield opening drain tubes and ran the rubber tubing down inside the cab all the way to the rear door sill. I didn't want any water dripping inside the cab or inside the door sills.
