Old 07-23-2019, 07:44 PM   #161
sharp21
Default First Flathead Build
I might just run a strap through the bores and call it a day
sharp21 is offline   Reply With Quote
Old 07-23-2019, 08:41 PM   #162
cmbrucew
cmbrucew's Avatar
Default Re: First Flathead Build
I heard men in Texas pick up flathead blocks like a six pack. Joking
Bruce
Works good
Lasts long time
cmbrucew is offline   Reply With Quote
Old 07-24-2019, 12:55 AM   #163
RalphM
RalphM's Avatar
Men in Alaska just pick them up off the floor and throw them in the back of the truck!
Yes, I’ve done it before.
RalphM is offline   Reply With Quote
Old 07-24-2019, 01:28 PM   #164
JSeery
JSeery's Avatar
I did in my younger days, but that's long gone!
Old 07-24-2019, 05:28 PM   #165
cadillac512
cadillac512's Avatar
Block upside down. Run a fan belt (cushion it with a rag) through the center main cap and hook it to your hoist hook.
Terry
cadillac512 is offline   Reply With Quote
Old 07-27-2019, 08:28 PM   #166
sharp21
Not to hijack my own thread, but I’m planning ahead. When the engine is done I’m planning to get a T5, rebuild it, and mate them up. Then I’m thinking of rear end.
Question: should I do an s10 rear for ease of use? Or should I pick up the banjo rear that is available right now locally for $150?
I’m worried that the banjo Rebuild will be more than I want to spend.
Input appreciated
Old 07-27-2019, 09:13 PM   #167
JSeery
JSeery's Avatar
An open later model rear end takes some work just to install. Have to have spring mounts and everything (there are bolt in kits). Or you can convert the banjo to open drive, but that requires addition of radius rods. Or you can modify the T5 to bolt up to the torque tube on a banjo. Any way you go requires some work and modification.
Old 07-27-2019, 10:23 PM   #168
sharp21
I’m kind of leaning towards an early s10 tranny, driveshaft and rear. Keep it as simple as possible.
Old 07-29-2019, 06:24 AM   #169
sharp21
What exactly is this but on the intake for? I’m having a hell of a time getting it off.
I’m aiming to drop everything off at the machine shop on Friday. Going to get a 3/8” threaded rod with some nuts and washers after work today. Then get the block off the stand and remove the idler gear. That’s the final piece before it’s game time.
Old 07-29-2019, 10:15 AM   #170
Mart
Mart's Avatar
That stud at the front is where the generator bolts on. There's not normally any reason to remove it. The nut should come off, though, of course.
Mart.
Old 07-29-2019, 04:07 PM   #171
JSeery
JSeery's Avatar
Generator and fan bracket, it is kinda a sandwich affair.
Old 07-29-2019, 05:57 PM   #172
sharp21
I’ll keep working on that nut.
In the meantime, time for liftoff!
Got it on a temporary bench
And put together a makeshift slide hammer
That didn’t work, so tried to turn it out using a little bucket
Let’s just say that the bucket list this round. Back to the drawing board
Old 07-29-2019, 08:39 PM   #173
Zeke3
Zeke3's Avatar
The oil pump idler pulley setup is different on the 8BA from the earlier 32-48 engines. Frank Oddo in, "Ford Flathead V-8 Builder's Handbook 1932-1953," recommends using a drift punch to drive the shaft out from inside the block. George McNicholl in, "How to Build Ford Flathead V-8 Horsepower," recommends using a 3/8 UNC bolt 1 1/2" long and a thick flat washer to pull against using a slide hammer with jaws to pull against the flat washer. Good luck with your project.
Zeke3 is offline   Reply With Quote
Old 07-30-2019, 09:23 AM   #174
sharp21
I’m worried about punching it out as I’d hate to damage it. Is this a part that should be replaced every time?
I’m planning next to make a puller out of a piece of strapping with a few bolts, thread the bolt I have up the middle, and screw it out.
If that doesn’t work I’ll get drastic.
Old 07-30-2019, 11:03 AM   #175
flatjack9
flatjack9's Avatar
Do yourself a favor and buy a slide hammer. You'd be done by now if you had one.
Old 07-30-2019, 11:58 AM   #176
Mart
Mart's Avatar
I don't think you necessarily need to remove it. If it rotates freely with no discernable wobble, and the teeth are in good condition you could leave it in place.
Just my take on it.
Mart.
Old 07-31-2019, 06:10 AM   #177
sharp21
Just my take on it.
Mart.
The machine shop is going to bake the block so I’m not sure that leaving it in is ideal.
Old 07-31-2019, 06:10 AM   #178
sharp21
The voice of reason...
Old 08-02-2019, 03:56 PM   #179
sharp21
Big day! Got the works dropped off at the shop. I’ll know next week what the actual condition is.
Billy (the son) owns it now, but Ted is still there and he cut his teeth on flatheads. Very happy having them so close to the house
Stay tuned!
Old 08-02-2019, 06:19 PM   #180
tubman
tubman's Avatar
Good luck man! Hopefully, no (or repairable) cracks.
