Old 09-23-2017, 02:32 PM   #161
1stford
1stford's Avatar
Default Re: 1936 Truck restoration
Originally Posted by Jeff/Illinois View Post
We're running 6.50/16's on our '36 PU I like them.
Have a 6.00/16 for a spare tire the 6.50 would be a tighter fit there.
Had to use an old 6.00 because the new 6.50 was a no go.
1stford is offline   Reply With Quote
Old 09-24-2017, 10:33 AM   #162
Steel 35
Steel 35's Avatar
Looks very nice!
Steel 35 is offline   Reply With Quote
Old 09-30-2017, 03:17 PM   #163
37stake
37stake's Avatar
Very nice truck! A suggestion for tires that I put on my '37 stake last year. 6.50 - 16LT from Specialty Tires of America http://www.stausaonline.com/ (Made in the USA). STA Super Transport LT Bias Ply tube type. To keep them round when my truck is parked, I use Flatstoppers.
37stake is offline   Reply With Quote
Old 09-30-2017, 08:48 PM   #164
1stford
1stford's Avatar
On the 36 truck windows is there not some type of rubber piece that keeps water from going between the window and door?
Old 10-21-2017, 08:29 PM   #165
1stford
1stford's Avatar
I've gotten to a point where I'm ready to start this up but when I tried there was not enough juice to turn it over. I charged the battery up and tried it again but still got the same thing, I'm using a 6V optima battery to get this going. I've been under the impressing, or thought this is a 6 volt system this whole time and wonder if it's possible these are 12V? One note is that all lights and horn work perfect with this battery, it's positive ground. It's just a shot in the dark but thought I'd post a few pics to see if it's possible to tell the difference? I am using a 6volt starter solenoid.
Old 04-07-2018, 11:45 AM   #166
1stford
1stford's Avatar
A couple updated pictures
File Type: jpg F650EC4B-04E9-4BE1-AC7C-C9DFB4B9068D.jpg (97.6 KB, 231 views)
File Type: jpg F66F74CE-63FF-4C21-B512-32CC79F17E89.jpg (35.3 KB, 156 views)
File Type: jpg 7A947E83-D5FD-424B-A5E6-4B11ACAD78C9.jpg (51.3 KB, 238 views)
Old 04-07-2018, 11:53 AM   #167
JSeery
JSeery's Avatar
Did you get it running?
Old 04-07-2018, 12:01 PM   #168
1stford
1stford's Avatar
I did. So simple and such a lesson for me. I added a ground from motor to frame and bam!
Old 04-07-2018, 12:03 PM   #169
JSeery
JSeery's Avatar
It's always the ground! Well, not quite, but it often is.
Old 04-07-2018, 12:50 PM   #170
AnthonyG
AnthonyG's Avatar
Kudos, really turning out beautiful!
Nomad
AnthonyG is offline   Reply With Quote
Old 03-08-2019, 08:37 AM   #171
1stford
1stford's Avatar
On the batter cover, that goes on the wooden floorboard, do you just use wood screws to hold that on? I don’t find anything that says what to do there?
Thanks.
Old 03-08-2019, 03:35 PM   #172
Don Rogers
Don Rogers's Avatar
The battery cover is a hold over from the model a era. Its held in place with spring strips.
Don Rogers is offline   Reply With Quote
Old 03-08-2019, 04:46 PM   #173
1stford
1stford's Avatar
Are these sold somewhere. I cut my hole out last night, I had ordered the one lasted for a 36 car.
Old 03-08-2019, 07:13 PM   #174
Don Rogers
Don Rogers's Avatar
Drake, Carpenter, C&G and others carry them. They cover a much small oval hole located in the floor board above the battery.
Old 03-25-2019, 10:03 AM   #175
1stford
1stford's Avatar
I thought I'd give an update as I finished the interior last night. I'm getting pretty close, hope to have this 4 year project done this week. I had a couple of questions I was hoping someone could chime in on.
1). The steering box says to use "heavy duty gear oil" what would that be?
2). My fuel gauge sits on E when it's at idol but goes up, to what I think is correct, as my RPM's raise. Any suggestions on where to start?
3). I don't love the cut that shows at the ebrake in the mat. Anyone have a better solution?
Old 03-25-2019, 12:09 PM   #176
Ben38
Ben38's Avatar
Looking Good!!!
Ben38 is offline   Reply With Quote
Old 03-25-2019, 02:38 PM   #177
Steve Seidl
Steve Seidl's Avatar
Smile Re: 1936 Truck restoration
Probably redundant but get a copy of the so called Green Bible as a great reference source.
Steve Seidl is offline   Reply With Quote
Old 03-25-2019, 08:27 PM   #178
Vintage Copper 47
Vintage Copper 47's Avatar
ANSWER to #3..get a piece of molded rubber in the shape of a long oval.. 3"by 5".. the distance of the stroke from brake on to brake off.. maybe make a slotted channel so it looks right couple of long screws.. just suggestion..
WALT
"Old enough for the experience & too young to know better"
Vintage Copper 47 is offline   Reply With Quote
Old 03-25-2019, 09:54 PM   #179
Talkwrench
Talkwrench's Avatar
Geez , quite different than mine .. So clean
1. Just use a semi fluid grease you'll be fine
2. mm dont know I use an aftermarket SW gauge.
3. not much you can do there is a boot that slides over the E brake, I cut a long flap that sits at the bottom of the E brake, under the floor mat so it covers any hole thats there backwards or forwards.
"Came too close to dying to stop living now!"
Talkwrench is offline   Reply With Quote
Old 03-27-2019, 12:47 PM   #180
Terranova
Man, thanks for keeping up on this thread. So many start but never finish. I'm going to book mark this for reference as I embark on my '36 fordor project soon. I hope to do a thread a thourogh said yours. Thank you again. Glad you're close to getting to enjoy driving. Grandpa would be pleased
Terranova is offline   Reply With Quote
