Old 10-15-2014, 10:49 AM   #1721
Vic Piano
Vic Piano's Avatar
Default Re: What I Did on My Lunch Hour
Gene, I'm not looking for them to help me install the Vintique part, (I don't want to use it). I want to know if they make a unit that will fit, and work, with the OEM radio installed.
Imagination is more important than knowledge.
Vic Piano is offline   Reply With Quote
Old 10-15-2014, 11:20 AM   #1722
Cecil/WV
Cecil/WV's Avatar
Vic, I saw a new conversion set up at the Tri State Truck show in Winchester, Va 3 weeks ago that had Bob drake name on it and it said the OEM radio wouldn't work with it. I don't know if it is made for drake by Vintique or not, but it looked like the motor hung way down below the windshield. It also said it would fit with no other alterations. The motor was hanging in a vertical position.
Cecil/WV is offline   Reply With Quote
Old 10-15-2014, 11:29 AM   #1723
Cecil/WV
Cecil/WV's Avatar
Vic,
If you have # 47-4050 that is liste on LMC, it is totally different that the one I described on the previous post. That one is similar to the original electric wiper motor on my '52 F 7.
Old 10-15-2014, 12:29 PM   #1724
Vic Piano
Vic Piano's Avatar
Cecil, the part # of the one they sent me is: 47-4052. I'm not happy about the part being from Vintique either, as I have not had good luck with their products.
Old 10-15-2014, 01:08 PM   #1725
Marv
Marv's Avatar
Vic with all your friends that you let use your garage, surely one of them would volunteer to ride on the running board and work your wipers. LOL
Marv is offline   Reply With Quote
Old 10-15-2014, 01:20 PM   #1726
Steves46
Steves46's Avatar
Vic, if you haven't checked Speedway Motors, here is the link to the model they have:
http://www.speedwaymotors.com/1951-5...-Kit,8723.html It did not address anything regarding the stock radio but I do know they have a real tech department. See you next week. Steve
If it aint broke, don't fix it!
Steves46 is offline   Reply With Quote
Old 10-15-2014, 01:50 PM   #1727
Vic Piano
Vic Piano's Avatar
Steve, I just checked with Speedway and it looks like the same unit that LMC Truck has. They also couldn't tell me if the unit will fit and work with the OEM radio installed. I'm waiting for a call back from New Port Engineering but, I think they sell the same piece... Looks Like I'll have to mess with the OEM Vacuum unit to get it working again... Too bad Ford didn't place the wiper motor on the engine side of the firewall...
Old 10-15-2014, 01:57 PM   #1728
Steves46
Steves46's Avatar
I was afraid of that for usually the parts houses get their stocks from what few OEMs in the classic car / truck market. Try spraying some white lithium grease on all the linkage joints. I did this along with squirting a little 3 & 1 oil into the wiper motor of my 46 and the wipers run terrific.
Old 10-15-2014, 02:34 PM   #1729
Vic Piano
Vic Piano's Avatar
Yup, I've done that in the past. The odd thing is, the wiper motor works when I remove the wiper arms and blades but not when the arms and blades are installed. The wiper set up I have, with a vacuum holding tank, was working very well however, now they are as effective as a screen door in a submarine when it comes to keeping water off the windshield... Oh well, I've still got a few days to mess with it, and, there's always Rain-X.
Old 10-16-2014, 08:02 AM   #1730
Vic Piano
Vic Piano's Avatar
Marv, that position is still opened, if you want to take it, its yours...
Old 10-16-2014, 09:18 AM   #1731
Vic Piano
Vic Piano's Avatar
Ok, here's an enigma... I went out this morning and started messin' with the OEM vacuum wiper system. I had the wiper motor rebuilt a number of years ago, and everything worked just fine until I let the truck sit for several months without using the wipers. Now, the wiper motor will work as long as the wiper arms and blades are removed (not helpful when its raining) I lubed the motor on the inside and greased the wiper arm assembly. Now, the motor will operate with one wiper arm and blade in place but will not work with both I've checked the vacuum hose, etc. and everything appears to be in good working order... I can't figure out why it will work with one and not both arms and blades in place. Got any ideas...
Old 10-16-2014, 09:23 AM   #1732
Marv
Marv's Avatar
I hope you get the wiper fixed. I would hate to drive to Florida, just to be the wiper man. LOL
Old 10-16-2014, 09:28 AM   #1733
Steves46
Steves46's Avatar
Vic, this is a real long shot...swap the existing wiper arms and see if the same thing happens. You could also pull a wiper arm from another one of your cars, say the 47 convertible and check the results. It may seem like a silly suggestion but you never know.
Old 10-16-2014, 09:48 AM   #1734
oldford2
oldford2's Avatar
There is a lot of "drag" with a dry wiper blade and dry windshield. Try wetting the glass like it was raining. Maybe too much pressure from the blade against the glass.
oldford2 is offline   Reply With Quote
Old 10-16-2014, 10:00 AM   #1735
Vic Piano
Vic Piano's Avatar
John, I did that, and tested with both wiper arms and blades... no good... I took one off and it worked... So, at least I've got a working wiper for the drivers side... I'll keep messin' with it and see if it comes back to fully functioning.
Old 10-16-2014, 10:11 AM   #1736
JSeery
JSeery's Avatar
Well I would think there is either too much drag in the wiper mechanism or the wiper motor. If lubing it helped for one blade would running it for a while loosen it up? If you have good vacuum and the motor is not leaking it about has to be drag. Anyway the motor has corrosion inside of it?
Old 10-16-2014, 10:23 AM   #1737
Vic Piano
Vic Piano's Avatar
JSeery, Everything worked fine for a good number of years before I let the truck sit. I'm guessing that things will loosen up after the lube has a chance find its way into all the parts. I'll keep trying with the hose putting a good volume of water on the windshield, to see if things improve with both wiper arms and blades attached. The wiper motor should not have any corrosion inside but, that is a possibility...
Old 10-18-2014, 03:57 PM   #1738
Vic Piano
Vic Piano's Avatar
Well, we finally got a chance to get back in the garage and mess with some Fatheads. Here's a shot of today's crew, from left, Don, me, Keith and Cliff.
We got the dash wiring done in Don's '50 Rag Top,
and some fixin' on Keith's '36 roadster
with a little help from his daughter, Angelique
and, before we knew it, it was PIZZA time...
We also got a bit more done on the '39 LZ, and we drove the '39 CS to lunch.
Thanks to the guys and gal for all the help and to Don for treating us to PIZZA!
Old 10-18-2014, 07:16 PM   #1739
green50
green50's Avatar
Looks like another fun day at the Piano estate!
Gene
green50 is offline   Reply With Quote
Old 10-19-2014, 10:49 AM   #1740
Vic Piano
Vic Piano's Avatar
Gene, we are trying to get some cars/trucks ready for the ride up to see you and other intrepid "Barner's" on the White Knuckle Tour and the Moonshine Festival. Vic
